Speaking of hard work and overhead work. This morning I started on the clutch job on this 06 mustang V6. Looks like a plus. I don't think the exhaust has to come off. It's single exhaust and the y is deep enough to clear the transmission coming out I believe. Drive shaft came out easy ,O2 sensors that were in the way came out easy, starter is off now. Shifter linkage unbolted. Only thing left is the crossmember bellhousing bolts, and don't forget to put the transmission lift under it before I pull it. Kkkkkkkkk
