Stop in for a cup of coffee
Was thinking.. only ground i should need is engine which i could do to the K-frame.. do the old single field regulators need a ground?
The OEM closed field (round back) alternators were iffy. If sufficientt ground was found through mounting hardware a actual ground wire wasn't needed but recommended.
Most of todays replacement alternators are the isolated field (square back) type. That would need one of the 2 field terminals grounded for it to function with the early type regulator. Those early round back units didn't put out enough juice to operate todays headlights and other accessories we desire anyway.
You're Welcome!
If you want to spice it up. Frame rails were black under the flange (sides) and also radiator support area viewed from the front.
All electric circuits need a way to return to ground. :poke:
They're all single field. :D
Really. 99% of the devices ground through their housings.
The alternator output returns through the housing. Doesn't matter if the field terminals and rotor are isolated.
Chrysler didn't bother and it worked fine.
Need to use screws with heads or washers that bite in.
Good Mornin!
Not sure what year they went to black behind the grille but mine was body color.. my frame rails under the flange were also body color (can't see it in that pic though)
I'm going to be using the 1962 headlights and no other real electronics.. so if i can get the stock alternator working i will be ok with it :) sounds odd but trying to keep some things as stock as possible cause my brain is stupid
Way easier than that. Basically a go/no go to ensure it does not overcharge.
And most of them will be gone.
I hope so. The sun kits usually sell fast. What I got going is they are all calibrated. Have a bunch of Snap on ones in the metal cases also. Tach/dwell and also a couple of cylender kill meters to boot. Couple of heathkit scopes. Lot of 6VDC meters, yes the dwell read different and a 12VDC meter is way off.
Wish i could hit carlisle.. only need a few things though.. M/T valve covers... and i would kill for a 1965 727 for the tailshaft/slip yoke but that's not gonna happen. and some rims.. so meh... will be at work as normal :)
Interesting. I'm not even sure where the block starts and stops on my car. We just copied what was there at the time. Now I have that book of assembly drawings and the paint instructions are included! But that book is only '67-69 A bodies
Random but I picked up this tube radio when we went downtown for the 4th of July celebration, Marconi 1940, works well. Since it said it was "rewired" I am going to take the back off of it and make sure it wasn't swapped out for solid state, wouldn't be cool to me and would go back to the shop I bought it from.
That wasn't a year model thing. It depends on how much body color paint shows through the grill(s). Even then they didn't bother to mask and properly paint the entire core support. They simply shot some black at areas where the body color would show through the grill(s).
I honestly thought they were all body color on the lower frame and front of the core support... My 71 challenger was the same way.. seems odd to me to not body color behind the grille
yeah... the bastard of all bastards.. i had no idea they were a 1 year car when i bought it so there are NO parts at all.. plus my k-frame/motor and trans mount are 61.... motor mounts are $800 a pair which will never happen :)
Shoot me a wish list. I am able to walk around this year and I am sure Tim will also. Also price range. Valve covers get stupid.
BTW.. in the pic above the wiring harness is held in by push in holders, not sure if they used those in A-bodies, need to get some though.. any idea on what to search for?
Roy and Jamie can probably fix you up. Roy is an old early B body guy. Mega Parts USA - Reproduction, NOS and Used Mopar Muscle Car Parts
Have a pic?
Yeah, i have seen them from $75 to $350 which blows my mind... there is a set of what looks like brand new Weiand aluminum ones bout a hour from me for $125 but they won't clear my rockers.. i'm not sure the M/T's will either but they are my favorite VCs
The radiator support? 67 up those are welded metal butterflies. Bend each end to capture the cables.
Plastic push in cable supports were used on the inner fenders
You can find plastic cable supports various places. I htink most resotrations specialty houses. fasterner plases like Restoration Specialty Supply, etc
Yup.. it's these... i need to stop posting today.. my brain isn't working :)
BTW. i'm glad places like detroit muscle tech exist.. they have some of the oddest parts that are awesome to get new.. plus they are 10 miles from me which is nice.
