Stop in for a cup of coffee
View attachment 1716129142 so a question for all those mechanics out there. Why is this the design auto makers adopted, Whjere the AC function is before the heat functions? I know why..... This is a ford, but GM did the same thing...
That selector controls the mode doors that direct the air through the different ducts... You have floor vents, panel vents on the dash, and defrost vents on the dash... Newer cars also have demist ducts that hit the side door windows to clear any fog from obstructing the side view mirrors... The slider is configured like that so it changes the mode as you sweep through the travel of the lever from top to bottom or vice versa...
A/C typically is used with panel vents or floor vents, or a combination of both called bi-level...
Heat is used for floor vents and defrost and sometimes a combination of both...
The top lever controls the temperature door that switches the air between the heater core and the evaporator, depending on if you are using heat or A/C...
68 Barracuda from "The Enforcer"
I like the good old days when things were simple defrost was a rag to wipe the fog off the inside of the glass, hand wiper blade and heat from the exhaust manifold. A/C was open the hinge on the windshield and roll door windows down.
No electronics just simple ****.
LoL...
Pneumatic wiper blades... had to keep an ice scraper inside the cab... flashlight to Illuminate the gauge
LoL...
Yea! didn't need the flashlight it never went over the speed limit but in winter you best have an ice scraper. lol
