Stop in for a cup of coffee
Hey the window on the Dakota poped out of the lower channel that raises the window. What do you use to stick it back in some sort of tape?
Was called innerseal. Have a body shop buddy? Otherwise urethane.
Some have clamps, loosen, set glass back in channel, roll all the way up and tighten clamps.
I should still ahve the one that came in the kit with the MP distributor. Might be a little more recent. I dont recall the blue heat sink. even if its the same p/n
Blue heat sink s good to 6500. Picked up a mopar kit cheap from 97. I mean cheap postage was more than the kit. At least I know they were real now in 97.
Chrysler Electric Ignition Conversion Pack 361 383 400 Point type to electronic | eBay
Now I gotta try to remember when I bought the kit. I think I used the tach drive distributor first couple years. Then parts store distributor, then tach drive again with a MSD timing retard hooked to a vacuum advance can with a switch. Might have been around '96 or 97 when I bought the kit.
Note to self: Start your sale threads on Wednesday morning so you can bump them on Saturday morning if you are Gold.
No, I will take trans and car back to NC to install everything. Ordered the last couple of things that were just delivered. Carb fittings for cross ram, water pump, starter, rad and fan shroud.
Awesome.. i'm down to radiator,starter all that little ****... And valve covers :( No idea what i'm gonna do for those yet
I polished the original chrome covers and 1 came out great, the other not so much, needs to be redone. I got a set of ‘66 black ones.
Yeah, i don't wanna end up with a pair that won't clear my rockers.. prolly gonna buy a set of the cheap welded up ones off amazon.. hate how they look but i know they will clear...
