Good Morning All! Well, I got the wood stacked so that is done but the 50 hour on the UTV is most definitely not! I had 3 filters to do, oil change part/filter is done buy the hyd filter is buggered up! My biggest channel locks don't fit around it, it's behind the other smaller hyd filter so hard to get to. I ended up punching a screwdriver through it.....yep, did that and lost a ton of fluid. So the end is pretty mangled but overall access to filter is okay as I removed a cage that protects the transmission. Will look at large channel locks today or ? Maybe a quality filter wrench, mine is a flimsy pos.
