Not that there is anything wrong with that.....................Is that a coming out post lol!
Scatter those strategically around the house and shop, your next date will like that. Anyone else need relationship advice?
Fred or the hat?THAT Is a work of art
Ha! it looked better on the roll before I wrinkled it up. LOLTHAT Is a work of art
Fred or the hat?
Fred or the hat?
Good to know that but sorry for the loss that sucks.So learned something on the HEI mod yesterday. The distributor has to have a 100% good ground on it or the low rpm section of the module will blow out. I had it grounded with the dist. machine clamp, and it came just loose and stopped working. WTF right? kind of find it tighten it all up again and nothing. Hell test the module rpm is bad. OK change it new gm module and works fine. So the bottom line is you need to use a metal base gasket and the o ring to ensure it is grounded properly. That sucks was a $120 pertronix module!
Ouch!So learned something on the HEI mod yesterday. The distributor has to have a 100% good ground on it or the low rpm section of the module will blow out. I had it grounded with the dist. machine clamp, and it came just loose and stopped working. WTF right? kind of find it tighten it all up again and nothing. Hell test the module rpm is bad. OK change it new gm module and works fine. So the bottom line is you need to use a metal base gasket and the o ring to ensure it is grounded properly. That sucks was a $120 pertronix module!
Wow!!So learned something on the HEI mod yesterday. The distributor has to have a 100% good ground on it or the low rpm section of the module will blow out. I had it grounded with the dist. machine clamp, and it came just loose and stopped working. WTF right? kind of find it tighten it all up again and nothing. Hell test the module rpm is bad. OK change it new gm module and works fine. So the bottom line is you need to use a metal base gasket and the o ring to ensure it is grounded properly. That sucks was a $120 pertronix module!
Expensive lesson for sure. I will put it on E bay!Good to know that but sorry for the loss that sucks.
Wasn't there someone that would hollow out a Mopar module and put in a GM module?I want to put together a off the shelf combo that will be bullet proof and better than MSD crap made now. Have to beat the hell out of it. I have a spare hei coil from the Dakota I want to try but need to get a pigtail somewhere. $40 at RA! No way.
I need to do something on my Scamp to keep the oil from getting into the distributor. I keep it cleaned out but might have to put a pump or something on it to keep the crankcase pressure down.I want to put together a off the shelf combo that will be bullet proof and better than MSD crap made now. Have to beat the hell out of it. I have a spare hei coil from the Dakota I want to try but need to get a pigtail somewhere. $40 at RA! No way.
Not sure it's HEI and came with my Blue Print engine.What year distributor some have a seal that were never put in for some reason and oil pools in it and drains out the holes.
