Stop in for a cup of coffee
Creamy shrimp pasta with mushrooms tonight. Not too fancy looking but it sure is delicious.
Almost
I felt the load increase on the drill (Karl)... and I have 89 psi at the oil pressure port on top of the engine. Just don't have oil at the rockers
Hmmm what did you do to the thing again? Just an intake?
I grind the od of old race and use it as a driver.i have an assortment of them. Safety glasses.
I was thinking somehting like that might be a way to do it.
Do you tap all around to drive the new one in, or put something across so th drive from the center?
Intake and new oil pump/ pickup.
Timing Chain and cover
Water pump
Fuel pump
Well, the oil.pump and pick up are working or you wouldn't have oil pressure. The intake doesn't have oil running through it so that's not an issue.
Sooooo....
I'm screwed with timing marks with the early timing chain cover, aren't I?
Different HB required?
Rookie mistake I think
