Frodee
Off center a bit
Just so you know using a nylon bristle will create heat and the nylon will melt on the steel and create a coating on bare steel that needs to be sanded off before applying primer. Something I was told by the PPG paint rep. so I just do it just to make sure I got it right.Flap sander and nylon bristle for like door jambs and trunk hinge areas?
