It must be crisp tender. ThanksWell compliments to the chef then, that looks good, broccoli doesn't look mushy
Lots of Karl material here.I’m here. I’m lurking. I’m trying to research parts and read up on front end suspension for the dart.
Thanks. I’ll let you know how I make out. You may hear me cursing at some point. Karl is definitely going to have to jump in here at some point. He’s missed out on a lot ofLots of Karl material here.
Being that I would NEVER NEVER go down that road I will just say good luck with your search.
Not sure what you are targeting Steph, but I went with a PST kit (OEM Rubber) on the 64, everything fit correctlyThanks. I’ll let you know how I make out. You may hear me cursing at some point. Karl is definitely going to have to jump in here at some point. He’s missed out on a lot of
Jokes.
Damn that looks good.
Dayummmm THat's my kind of chop!
What parts are you bouncing around?I’m here. I’m lurking. I’m trying to research parts and read up on front end suspension for the dart.
CARNIVORE! Looks good!
Sway bar and adjustable shocks helped mine.I’m here. I’m lurking. I’m trying to research parts and read up on front end suspension for the dart.
That’s what I’m reading up on. Trying to decide what kit is better. I don’t exactly want to break the bank but I’m not looking to cheap out.Not sure what you are targeting Steph, but I went with a PST kit (OEM Rubber) on the 64, everything fit correctly
I’m looking to replace all the bushings and ball joints. I want to replace the shocks as well. What other parts would be worth upgrading to make it a better driver in the front.What parts are you bouncing around?
Do you remember what sway bar you went with? I’ve been reading through the forums on front end suspensions and searching YouTube for videos.Sway bar and adjustable shocks helped mine.
I have a complete QA1 front suspension and still using my stock torsion bars. Seems to work real good for me.Do you remember what sway bar you went with? I’ve been reading through the forums on front end suspensions and searching YouTube for videos.
To grasp the real essence of Broccoli you need to spend all day downwind of a Broccoli field about 3 days after harvest and they have taken the flail mower to the remnants for composting before they drag the discs over it
Hey ya Tim. How goes it??Evening all. Hey, Steph, stay away from poly bushings....ESPECIALLY lower control arm bushings!!! MOOG only IMO
