Unconventional
Some time between sunset and midnight, Elon is supposed to launch that Falcon 9 they sheltered during the thunderstorms the other night.
Not sure.Why if it is their line they find?
View attachment 1716229955Good morning all. Rainy here. I have one more day off from work. I’ve been working on touching up the paint on the dash of the dart.
Fixed for you!View attachment 1716229955Good morning all. Rainy here. I have one more day off from work. I’ve been working on touching up the paint on the dash of the dart.
Bought a new one for my 904 and yep, junk.Anyone happen to have a 69-77 neutral safety switch for a 727? I keep reading the new ones are junk.
I can check but I think the one I have is from my 64Anyone happen to have a 69-77 neutral safety switch for a 727? I keep reading the new ones are junk.
Prob got a pic in case the rooster comb was changed?Anyone happen to have a 69-77 neutral safety switch for a 727? I keep reading the new ones are junk.
Can't recall where I got the last one. Usually I walked into a transmission shop I had some dealinhgs with and asked for one.Anyone happen to have a 69-77 neutral safety switch for a 727? I keep reading the new ones are junk.
@halifaxhops I know you are into ignition but old senders and switches would be good as well.Anyone happen to have a 69-77 neutral safety switch for a 727? I keep reading the new ones are junk.
When it comes to safety, overkill is better than getting killed!So.. i need to make seat belt mounts for my car as it didn't come with any... i see guys using just a bolt and big washers.. but i was thinking of doing like a 4x4" plate with holes in it and plug welding it to the underside of the floor.. am i overthinking? also.. what bolts do seat belts use 7/16-20? Also.. need to find some gray seatbelts
Yep, a must do and don't forget those steat Bolts, they need a good reinforced area to hold you in placeWhen it comes to safety, overkill is better than getting killed!
Me as well, lap belt over a 66 Barracuda buckets.Since i can only run a lap belt i'm gonna eat a steering wheel no matter what... my goal will be to not hit ****
