Unconventional
there should be a sonic boom momentarily. it's returning to SLC4. and there it was BOOMBOOM
Mo fun in that. Doing body work, and a few beers, looks great! Get up in the morning. Good god! Have to redo it. More then one time this happensJust ordered another pair of rear spring perches... in my normal fashion i'm going to redo something i did 3 weeks ago.. I need to learn to get it right the first time
Something go boom?TAKE COVER!!
Another Vandenberg launch!
Like the 3rd this month
Why?Just ordered another pair of rear spring perches... in my normal fashion i'm going to redo something i did 3 weeks ago.. I need to learn to get it right the first time
god i don't even wanna think of bodywork i'm very close to starting on that...Mo fun in that. Doing body work, and a few beers, looks great! Get up in the morning. Good god! Have to redo it. More then one time this happens
Just the main engines when they returned to SLC 4 the launch site. No autonomous landing barge for this one.Something go boom?
This house is the worst hodge podged, rule skirting I’ve ever seen. None of the wiring is to code, the plumbing looks like someone robbed a travel trailer from the 1960s and mixed it with cpvc and brass pipes.Yeah...
There's nothing "Free"This house is the worst hodge podged, rule skirting I’ve ever seen. None of the wiring is to code, the plumbing looks like someone robbed a travel trailer from the 1960s and mixed it with cpvc and brass pipes.
The shower valve handle broke today. Stripped. Open the back panel, sure as there is sun, they used 1/4 inch CPVC with a bunch of reducers to the valve and out of the valve. Enough cement to supply half the county. And this handle is so old no one at 5 stores in town has anything that’ll work. So my only option is to tear it all out, and buy a new valve plus head and handle.
So I’m trying the redneck solution first… JB Weld… I just need to get through until fall when I hopefully can start on the new house
That's the easy part doing body work. You'll do fine just let me know when you start and I can help.god i don't even wanna think of bodywork i'm very close to starting on that...
I did my perches a few weeks ago and somehow got the axle bout 3/8" offset (i thought i was smart doing 1 side at a time, nope) so this time i will do both at the same time and actually measure backplate to spring. and even fit the tires to check clearance... thinking smart
I have a nasty vibration in 2nd gear ( on jack stands) and i'm 99% sure i have too much negative pinion, not sure how much would be needed to cause that though
Hell i wish you were local..i hate bodywork soo much i just have to do the fenders and lower quarters, all metal work is done, filler and sanding needed.. hoping the paint matches close enough that i can live with itThat's the easy part doing body work. You'll do fine just let me know when you start and I can help.
Don't, whatever you do buy cheap bondo. It will cost you more in sandpaper and shoulder pain than it's worth.Hell i wish you were local..i hate bodywork soo much i just have to do the fenders and lower quarters, all metal work is done, filler and sanding needed.. hoping the paint matches close enough that i can live with it
Naw..i know a bit. but not pro mode. i'm a hack.. i got duraglas to rough in and was just gonna use top glaze over that (i got reducer for the duraglas to thin it so it spreads nicer) btw.. not sure if it's duraglas brand.. but fiber reinforced fillterDon't, whatever you do buy cheap bondo. It will cost you more in sandpaper and shoulder pain than it's worth.
Keep me posted and I'll help as much as I can. Not sure how much you know so forgive me if I sound like you don't know much.
What body filler do you recommendDon't, whatever you do buy cheap bondo. It will cost you more in sandpaper and shoulder pain than it's worth.
Well…. Red neck solution failedThis house is the worst hodge podged, rule skirting I’ve ever seen. None of the wiring is to code, the plumbing looks like someone robbed a travel trailer from the 1960s and mixed it with cpvc and brass pipes.
Duraglas is hard to sand and I use it on the low spots and edges, then use Evercoat mud over that and then glaze if needed.Naw..i know a bit. but not pro mode. i'm a hack.. i got duraglas to rough in and was just gonna use top glaze over that (i got reducer for the duraglas to thin it so it spreads nicer) btw.. not sure if it's duraglas brand.. but fiber reinforced fillter
What did bad Chad doI got the duraglas/reducer idea from watching bad chad... who i can't watch anymore cause... reasons but the guy can spread mud
yeah it's that experience that makes the difference.. I do bondo like i do drywall mud... put it on.. sand it off... put it on again.. sand if off.. til i get pissed and say **** itDuraglas is hard to sand and I use it on the low spots and edges, then use Evercoat mud over that and then glaze if needed.
1st coat I sand with 36 grit then go to 80 and then 180. If you let the bondo dry to long on the first layer it gets to hard to sand. Let it get almost dry then hit it with 36 grit. If it's still to green it will gum up the sand paper and not be able to clean it out to easy.
Makes a big difference in wearing out sand paper and arms.
nothing bad... i just don't like the stuff he makes and i think he's just better in smaller dosesWhat did bad Chad do
We all been there. LOLyeah it's that experience that makes the difference.. I do bondo like i do drywall mud... put it on.. sand it off... put it on again.. sand if off.. til i get pissed and say **** it
