You may have to stop for gas more than everyone else but you will be in the lead all the way.
No idea................True what kind of mpg do you see in that thing
At every stoplight and on ramp!
There’s an app that works really well…No idea................
Gas gauge doesn't work
No speedometer
No odometer
Underside i use a good rust paint. I cheap out and go one coat. Should do 2What would you all use to undercoat a truck bed
Which one? I have a tach, that's about it. Running Waze in MN back and forth to the show at least I had a speed to go by.There’s an app that works really well…
So, nerospine surgeon said my issues likely stem from C2-8. I have 2 bulged discs below there. He is ordering an EMG. Apparently they can identify the individual nerves causing issues so they can find the orientation and root cause.Interesting you mention that. I went to the Orthopedic surgeon and they pointed out my 3 problem areas. I went in for the elbow pain and tingling but they wanted to do 3 separate operations starting with the arthritis in my neck. Nope! I went to a Neurologist and they wanted to cut my elbows open and move the tendon to the other side of the bone. Nope! I went back to my Chiropractor and have been there ever since. She can help with the pain but can't fix the issue.
Mercury Marine has a free app for boaters, but it has GPS speed as a feature. It is what me and my boy useWhich one? I have a tach, that's about it. Running Waze in MN back and forth to the show at least I had a speed to go by.
Wow, that's a cool thing. Keep us posted. They know what goes where. I have a bulged disk with "moderate" issues on L4-L5. No wonder why I have leg/walking/standing issues.So, nerospine surgeon said my issues likely stem from C2-8. I have 2 bulged discs below there. He is ordering an EMG. Apparently they can identify the individual nerves causing issues so they can find the orientation and root cause.
Ive had this one about a year now and used this one all thru power tour. Worked great even when signal strength is weakWhich one? I have a tach, that's about it. Running Waze in MN back and forth to the show at least I had a speed to go by.
You can customize the colors and font and such tooWhich one? I have a tach, that's about it. Running Waze in MN back and forth to the show at least I had a speed to go by.
Thanks Chris
All I wanted was transmission mount that didn't fail in 3 years. Figured polyu was more oil resistant than rubber.I bolted the torque strap down so its very pre-loaded. It works but I'm not happy with it.
Glad you know what you're doing Matt I'm lost on figuring it out.All I wanted was transmission mount that didn't fail in 3 years. Figured polyu was more oil resistant than rubber.
Now looking for some sort of oil resistant coating for the rubber mount.
Found some expensive products in McMaster. One is a PVC coating and another is a 2 part Poly urethane.
Maybe just fix the oil leak?Glad you know what you're doing Matt I'm lost on figuring it out.
Feel like I'm wasting a ton of time.Glad you know what you're doing Matt I'm lost on figuring it out.
Ideally. Yes!!!!Maybe just fix the oil leak?
Smiles per gallonNo idea................
No speedometer
No odometer
Nice pic, looks like the sh*t could hit the fan any moment there tho
Hope that's not heading your way.
