Maybe....Thinking bout it is worse than just doing it.. 2 hours and it will be on the ground
Still up in the air if it will come out.......I did not plan on taking this out again......my fabrication skills might have left no room to remove....Maybe....
The draggin wagon, buddy’s first car was a monaco wagon, same colour. If i was a wealthy man i would find one and fix it up for him. Hes soon to be a grandfather, perfect grandpa mobile.
I like to build serviceability into my projects. Maybe thats why it takes so long.Still up in the air if it will come out.......I did not plan on taking this out again......my fabrication skills might have left no room to remove....
Its just the top. I might have left enough room. I had to make sure any modification allowed the use of the stock console location. That was the issue.....I like to build serviceability into my projects. Maybe thats why it takes so long.
Seriously can’t just unbolt at the manifolds?Still up in the air if it will come out.......I did not plan on taking this out again......my fabrication skills might have left no room to remove....
Headers, shorty. That is not the issue....Trans has to be moved back to remove, just about an inch. locating pins. The Tunnel over the GV unit had to be modified, rebuilt completely, and there is not much room to the rear. We will see. Might be able to tilt the engine trans unit to remove,Seriously can’t just unbolt at the manifolds?
The engine is already tilted down some, a few degrees, to get it to fit. Getting that GV to fit in this car was a big project...IMOHeaders, shorty. That is not the issue....Trans has to be moved back to remove, just about an inch. locating pins. The Tunnel over the GV unit had to be modified, rebuilt completely, and there is not much room to the rear. We will see. Might be able to tilt the engine trans unit to remove,
ohhh i didn't know you had a GV... yeah should be able to tilt it down way more then enough.. dont' forget to check fan to radiator space when you do itHeaders, shorty. That is not the issue....Trans has to be moved back to remove, just about an inch. locating pins. The Tunnel over the GV unit had to be modified, rebuilt completely, and there is not much room to the rear. We will see. Might be able to tilt the engine trans unit to remove,
The GV is the issue....ohhh i didn't know you had a GV... yeah should be able to tilt it down way more then enough.. dont' forget to check fan to radiator space when you do it
Engine is already tilted, almost to the dist cap hitting, just to make install work....so............for sure will have to remove dist....ohhh i didn't know you had a GV... yeah should be able to tilt it down way more then enough.. dont' forget to check fan to radiator space when you do it
well.. pewp...Engine is already tilted, almost to the dist cap hitting, just to make install work....so............
Agree. I installed everything as a unit from under car. Lifted and rolled unit in. Slick. Now I might have to reverse that process. Different kind of work.....Have to roll car out of garage because there is not enough clearance to lift car high enough in garage...well.. pewp...
I would remove the dist cap or dist even if you have to and try leaning it back a bit.. could also just loosen the k-frame bolts to give it a little more tip to clear.. only takes a little in the front to drop that back a lotAgree. I installed everything as a unit from under car. Lifted and rolled unit in. Slick. Now I might have to reverse that process. Different kind of work.....Have to roll car out of garage because there is not enough clearance to lift car high enough in garage...
Probably could... probably sell about 6 of themPatented?
Really has the rough spots ironed out......Probably could... probably sell about 6 of them
Could you leave the whole thing bolted together and simply drop the k frame and lift the car off of itAgree. I installed everything as a unit from under car. Lifted and rolled unit in. Slick. Now I might have to reverse that process. Different kind of work.....Have to roll car out of garage because there is not enough clearance to lift car high enough in garage...
Plan b.Could you leave the whole thing bolted together and simply drop the k frame and lift the car off of it
It's not simple. Lots to unhook. Remove. But a definite plan BCould you leave the whole thing bolted together and simply drop the k frame and lift the car off of it
Prototype took about 8 minutes to make with scrap lumberReally has the rough spots ironed out......
Fooled me. Very polishedPrototype took about 8 minutes to make with scrap lumber
It was a "How the F$%k" moment while following the TSM directions...
"Have yourAssistant...."
And I have just a few wrenches
