Sorry had to do a run to the pet store for pellets for the pond fisn.Everyone disappeared. Like I got a private room. here.
IndeedAlways try to get the sales on these. Regular prices are nuts. Looking at the original $419 on the 2nd one, that would be comparable considering it only has one battery which is always a huge factor in cost. I have M18s and for those they will try to trip you with '2 batteries' being one good size and a 2nd of much smaller Ah.
Do you leave a radio on when you leave? Small pile of cloths so she knows your coming back.Then got home did not cage the dog for the real first time. She definitely has being alone issues for sure. Lets just say cage for now when we are gone!
Sure keep Breakfast all to yourself.OK, I'm done....
I think mine are all between 4 and 6. They all appear to be same size physically.Indeed
I have a 5, 3 and 1.5AH batteries for my set. I could use another 5.0
More here. Come on over.Sure keep Breakfast all to yourself.
They used to hang horse thieves. You stole a horse you knew what you had coming....just saying....not many horses got stolen. Same as shop lifting in mass..
Disclaimer
That would put a stop to a lot of this crap going on.I want to shoot guys stealing massive cart loads of tools.... really..
The 1.5 is about half the size. Handy for light household stuffI think mine are all between 4 and 6. They all appear to be same size physically.
that's not too bad... clean the inner part of the frame.. i would corroseal it then paint... then make a patch...Ok boys and girls
Sitting here thinking... Which is dangerous
Pulled that patch off the drivers floor. 36 sheet metal screws and who knows how much adhesive.
It's kinda ugly, but I think manageable.
Glad I pulled it off. It was rusting still and the frame extension was full of dirt.
So.... What next. I think I can get away with a patch and it'll be less complex than a full floor pan.
Can you order 1/2 a pan?
Thoughts?
Snaked the shop vac in there. I'm going to grab a chimney vent brush to run up... Then a can of Eastwood frame spraythat's not too bad... clean the inner part of the drame.. i would corroseal it then paint... then make a patch...
Yes. Giving myself some playroom. I'll see how far it goes when I start removing the rot. There's some spot welds I'll need to grind outbtw.. when you cut out the old ****.. cut 1" more than you think you need to.... trust me.. i cut too short on all my **** and spent time welding to rust... can't really use butt and cut on that.. i keep big sheets of project paper to make templates from
Cool. Yeah everything other than the floor pan is solidmine had old scale rust completely packing the inside on both sides... luckily still pretty solid and saved it
cool... couple of patches, some seam sealer and paint and away you goCool. Yeah everything other than the floor pan is solid
