The what? I have fished with Alemite or that may be Hellgrammite's
Did 4 front end alignments on my car since I owned it and wore out 3 sets of tires from people not knowing how to do old cars with radials.You can get pretty darn choose with string and washers
Wish I was closer. The Alemite system works really well
Skosh charts work pretty goodDid 4 front end alignments on my car since I owned it and wore out 3 sets of tires from people not knowing how to do old cars with radials.
My son did the last alignment and it's been good for a long time. Front end specks for factory settings are different when running radial tires.
There is an under dash antennae. I had my hand on one 3 days ago, should have bought it. I should go back and see if he still has it.There might be a magnetic base antenna out there somewhere. Radio Shack, where are you when we need you?
Couple of floor tiles, some grease, protractor and a permanent markeryeah, i wanna do my own alignment.. don't wanna blow $200 on turnplates.. there are ways to make ones at home, i need to get on that.. winter is coming
It’s definitely going to be a learning curve but around here it’s been hard to find shops that will touch the alignment on the older vehicles. I’m hoping by Saturday night to be able to take a stab at it. We do have a set of plates my father in law passed over to us.You can get pretty darn choose with string and washers
Think I'd **** myself jumping out of a perfectly good airplane at 30,000 feet..I'll jump out of a plane from 30,000 feet, 600 foot cliff bungee jump from a 200 foot tower... But I hate roller coasters. I think it's a control thing
A buddy put 5:? Gears into his old 60 ish chevy, inline six. Kicked his buddy’s *** from light to lightahaha not with my motor.... 318 power baby! sounds like it's going fast though..
Hmm.. i tried ceramic tiles, they shattered You talking like the stick down plastic/nylon ones? might workCouple of floor tiles, some grease, protractor and a permanent marker
There's some write ups on how. Caster is the only thing that was kinda impossible to getIt’s definitely going to be a learning curve but around here it’s been hard to find shops that will touch the alignment on the older vehicles. I’m hoping by Saturday night to be able to take a stab at it.
yeah, i just hate revving a motor non stop, feels like i'm beating it for no reason.. plus just going to the gas station people were getting pissed since i was doing 40ish in a 50 that people do 70 in Once it's aligned and i fix issues i can polly go a bit faster thoughA buddy put 5:? Gears into his old 60 ish chevy, inline six. Kicked his buddy’s *** from light to light
Yeah. The peel and stick ones work fine.Hmm.. i tried ceramic tiles, they shattered You talking like the stick down plastic/nylon ones? might work
yeah, i have offset bushings already installed and i think the max i could get was like 3..There's some write ups on how. Caster is the only thing that was kinda impossible to get
yeah, i have seen people use like tiles with garbage bags in between instead of grease tooYeah. The peel and stick ones work fine.
I have actual plates but used the tiles and string the first time
It's surreal... Especially at night with a moon.Think I'd **** myself jumping out of a perfectly good airplane at 30,000 feet..
My alignment machine has specs from the 40’s to 2016. I know it takes a little research to figure out the specs for radial tires.It’s definitely going to be a learning curve but around here it’s been hard to find shops that will touch the alignment on the older vehicles. I’m hoping by Saturday night to be able to take a stab at it. We do have a set of plates my father in law passed over to us.
It's surreal alright especially when you hit the ground with a thudIt's surreal... Especially at night with a moon.
I bet it would be.It's surreal... Especially at night with a moon.
You see your shadow on top of the cloudsI bet it would be.
We are road tripping to you Frank if we can’t figure it out ourselves here.My alignment machine has specs from the 40’s to 2016. I know it takes a little research to figure out the specs for radial tires.
Now that would be really cool to experienceYou see your shadow on top of the clouds
All but hero around here. But don’t see grinder much. Usually see that for hot Subs. I think some places consider a sandwich that is normally served cold a grinder if they toast it.Geographical... What did folks grow up with?
Sub
Hero
Hoagie
Grinder
Grinder, I think was a unique Rhode Island thing.... Shredded lettuce.
