Why not just a vacuum accumulatorYeah I got a big shaft and need a vac pump. Wish I knew about hydro brakes before I did what I did.
What's wrong with the Torker 2well - you know it was a purpose built race car - I am just trying to bring her down to a more streetable beast.. smaller cam - smaller carb - and a better intake than the Torker II that was on there
the booster and crusty MC was on there B4 I did the engineMike what is your set up now on the brakes?
too much intake - took it off and went with an Edlebrock Air GapWhat's wrong with the Torker 2
Wow moving right along this morning. Took a run for some ice. Waiting on the sister in law to pick up my wife so I can start pulling out all the chairs and start setting up.
exactly - got that sitting on the bench - just not sure I want to use it and no boosterThis is basically what I have.View attachment 1714946673
disk on all 4What you got disk/ 10" drums?
It's that Columbian mix from yesterday. Just hooked up another pot. Wife just gave me a fathers day gift she forgot about. Pic on the way.What you smoking old man you have been up all night there.
Wifes 60th.Good Morning there Wolfie...You having a party?
What engine? I'll be running a Torker 2 on my 440too much intake - took it off and went with an Edlebrock Air Gap
I tried the manual on mine ti was like stopping the queen mary. You have to get a lot of fluid to four calipers. You can put it on with the adapter plate and see. You definitely need a adjustable prop valve for sure.
I thought prop valve was always needed for disc/drum, but not for either if front and back are same??I tried the manual on mine ti was like stopping the queen mary. You have to get a lot of fluid to four calipers. You can put it on with the adapter plate and see. You definitely need a adjustable prop valve for sure.
I'll be running the XE285I got the torker II on mine and I like it with a 750 eddy on it. Then again I have a big shaft!
