Stop in for a cup of coffee
67 to 76 A bodies have virtually the same engine bay.
So ... the B block would fit just as well in a 74. But the RB is taller which puts the exhaust ports higher up too. Maybe that causes more clearance issues?
None.... Ya gits lotsa Dirt !!
I suppose it is necessary to add the reinforcement tube you always see when they're gone, right? And then you might as well go coilover?
Yes, This is why ma Mopar installed mostly 383' or B blocks rather than 440's or RB blocks in the A body. Lots of A bodies with 440's, out there, but it is a tighter fit. This is also why guys take a 400 B block and stroke it up to 500ci, It fits better.
It was actually your block that got me thinking. I thought maybe you wanted to get rid of it and my mind wandered from there ...
Im stuck buying another one lol. Whats the going rate of 440s over there?
and the 400 block is a tad lighter too
no need for coil overs - mine still has the stock style front suspension with KH disk
They're pretty expensive compared to in the states but parts are pretty common. I see 906 heads for $200 pretty often and the occasional rotating assembly, also pretty cheap - cast ones. A lot of people modify them and the stock stuff ends up just laying around or being sold off cheap. Just like over there, I suppose.
So i need to buy a bunch up and send over there?
Yup. Or build street engines and ship over. Then we're talking serious money. Not sure how many you can sell in a year but a guy I know builds and sells engines, mostly big blocks, all the time. A decent 440 is probably somewhere around $8,000 - $15,000 depending on configuration.
hmm..... whats core engine going for?
You mean a complete but stock 440? Prolly $1,500 - $2,500 if it turns around. Upper segment with trans. An empty block a few hundred bucks. Less with the damage you have, of course.
These are my guesstimates based on what I remember seeing in the mopar for sale group on Facebokk I'm in.
So about double then.
Well .... My power just came back on.. after being out for 2 hrs... Good excuse to go to the BEER store... Guess I need to git busy now !!
