ScampMike
Despicable Damn Yankee
oh, you are here - just in "stealth" mode... how the heck are ya?I thought it was a M/C sidecar goin' solo
Morning All !!
Trying to find out why the dishwasher machine is leaking underneath... PIA
Pulled it out some without disconnecting, removed the lower access panel... Ran it... Now I don't see a leak....It is probably the pump that removes water from it. or the connection on either side of it. Turn off the water to the dishwasher and unscrew it from the cabinets and pull it out and turn it upside down and take a look at it. There isn't much to them and I'm sure you can fix it yourself if you can get ahold of a pump. that's my two cents but I haven't done that in at least 10 years.
oh yikes - kinda like my GDed hot tub - I can see where the H2O is dripping .. but where the F is the actual leak!!!??Morning All !!
you fixed it!!!!Pulled it out some without disconnecting, removed the lower access panel... Ran it... Now I don't see a leak....
I had a discharge hose kinked when it was all the way in and the pressure caused a leak on mine. PIA to figure out and a mess also!Pulled it out some without disconnecting, removed the lower access panel... Ran it... Now I don't see a leak....
another happy day here in hell...Good n' you?
It's always the doohickey that goes in to the whatchamacallit. Hope that helps!oh yikes - kinda like my GDed hot tub - I can see where the H2O is dripping .. but where the F is the actual leak!!!??
hope he uses KYI think I have to shine the RON light in the sky today to get a hand.
Why Kentucky??hope he uses KY
not really - I already knew that...It's always the doohickey that goes in to the whatchamacallit. Hope that helps!
because they have the best fried chickenWhy Kentucky??
Thanks. I get it now.. Shine a signal light in the sky and you get fried chicken and a handy..because they have the best fried chicken
Bet @Ddaddy can do something with that one.Thanks. I get it now.. Shine a signal light in the sky and you get fried chicken and a handy..
morning.Morning folks!
Still having issues Ray? Was i off on the measurement?Well spent half of yesterday trying to get the valve cover under the blower motor think I have to take both mmounts out then push the engine to the DS. Fun crap right there I should just use flex seal!
enough?so Mikey....its snowing.....
They will work just cant get them over the rocker arms with the engine up. I really have to do that heater blower mod.Still having issues Ray? Was i off on the measurement?
