dukeboy440
yeah, it'll be towards the upper end of that due to the extra stiffening in the bodyMine was a Rag top, weighs a little more if I remember right.
really?! Hell, I may have to reconsider selling mine and getting a B body 8.75.....And that is a good price!
huhThis is kind of cool, got a pop up on e bay.
Magic Glue Clean Tool Interior Panel Air Outlet Vent Dashboard Dust Cleaner Gum | eBay
sign up for AIM's emails. They sent one out saying they were in stock and I picked them up right away. Even the shop I did the transfer thru could not believe the price of them. If I get another email, I can let you know on Facebook as well if you dont want to sign up for it.NO WAY, thats exactly what i got though mine had the removal trigger guard
Hence why Im just going to get all 4.I would bet ya Ramie, that once you get the rear ones in there, you'll turn around and get the front one PDQ
you betchaman, a body 8.75s are high aint they
But in this market, most are ditching the 4 inch pattern to get into different wheels. So a limited demand.really?! Hell, I may have to reconsider selling mine and getting a B body 8.75.....
im not familiar with AIM?sign up for AIM's emails. They sent one out saying they were in stock and I picked them up right away. Even the shop I did the transfer thru could not believe the price of them. If I get another email, I can let you know on Facebook as well if you dont want to sign up for it.
yeah.But in this market, most are ditching the 4 inch pattern to get into different wheels. So a limited demand.
Aim Surplusim not familiar with AIM?
Why what? Used poly cause I always thought these things had very sloppy suspension. Figured it would be good to tighten things up a bit. Did not use the slippery little LCA poly for same reason. Thing was just floating in there.really - why?
for about $350 you can buy new axles... another 100 and do green bearings.. lose the original adjuster set upBut in this market, most are ditching the 4 inch pattern to get into different wheels. So a limited demand.
But you can re drill for the 4.5 pattern.
whats wrong with the adjusterfor about $350 you can buy new axles... another 100 and do green bearings.. lose the original adjuster set up
that's why what...Why what? Used poly cause I always thought these things had very sloppy suspension. Figured it would be good to tighten things up a bit. Did not use the slippery little LCA poly for same reason. Thing was just floating in there.
you can't buy parts anymore of you F it up and they can be touchywhats wrong with the adjuster
Doc diff sells axles with green bearings that you can leave the piece in the diff, cant think what the heck its called. Has spacers. That is what I put in "my" brothers 68 Dart.for about $350 you can buy new axles... another 100 and do green bearings.. lose the original adjuster set up
OHHH so i should plan to go to green bearings then. I just thought it was some environmental thingyou can't buy parts anymore of you F it up and they can be touchy
I have them in my car as well, nice axles!Doc diff sells axles with green bearings that you can leave the piece in the diff, cant think what the heck its called. Has spacers. That is what I put in "my" brothers 68 Dart.
thrust spacer I thinkDoc diff sells axles with green bearings that you can leave the piece in the diff, cant think what the heck its called. Has spacers. That is what I put in "my" brothers 68 Dart.
sheeesshOHHH so i should plan to go to green bearings then. I just thought it was some environmental thing
