Wrong Hood Maybe ??any other issues? ..dim lights? ..squealing belts?
Ok, paint by numbers then...start with the plugs (pull and check/clean as necessary) check timing and then adjust carb. Set kick down linkage properly and then drive it to burn everything out, new fuel, then repeat carb adjustments.Should be fine ,. Kept it low and used stabil since I changed the tank a couple years ago. Most of what's in there now is not more than a few months old. Certainly very burnable. I figured I would be retuning through the first couple tanks anyway.
Could be...a scoop is supposed to face forward and actually 'scoop' air.Wrong Hood Maybe ??
I could loan him mine - it might helpWrong Hood Maybe ??
that's like saying a full bed cover is better than a half bed cover... on a pick up truckCould be...a scoop is supposed to face forward and actually 'scoop' air.
These are mud tires......Yeah, you found just the right soft spot and sunk too far to get it out without mudder tires.
whaaaaat... cut the comedyThese are mud tires......
What da hell are you talking about?? Half a bed cover? Is that like putting a tarp over half of the hole in your roof?that's like saying a full bed cover is better than a half bed cover... on a pick up truck
Don't tell me that you think the little M&S rating on street tires means that they are actually any good in mud?These are mud tires......
I used them exclusively for years - not fond of the newer version - but it is what it is
- or these guys that think a tailgate net is saving them gas...What da hell are you talking about?? Half a bed cover? Is that like putting a tarp over half of the hole in your roof?
Mud performance is good. Treadwear not so much is you drive it on the street...
I gotta tell ya - those General Grabbers I bought this past summer - very impressed - way more so than I ever imaginedMud performance is good. Treadwear not so much is you drive it on the street...
Yeah, no street life...built for mud only. I like the All-Terrain T/A better for an all around tire unless it's a dedicated (or often in mud) mudder truck.Mud performance is good. Treadwear not so much is you drive it on the street...
is that a trick question...Since we are talk in mud.. You what to here a dirty joke.
LOL - you're in the coffee shop - of course we do!
Yeah, there's a lot of misconception about aerodynamics out there. Covering the front half of the bed reduces the turbulent "drag" zone and cuts drag behind the cab by 50%. Normal high pressure air fills the rear uncovered half of the bed and allows the air to seek a more laminar and uniform path over the tailgate without raising the high pressure zone up above the top edge of the bed like a full cover does. A tailgate net lowers the high pressure air zone below the top edge of the bed but increases the turbulent zone and extends it further back from the cab.admittedly, not enough increase to justify cutting you tonneau in half.. but it was an interesting result
Good Point! LOLLOL - you're in the coffee shop - of course we do!
