Oops...
it's a step in the right direction - now you can get 'er out on the road and experiment -test & tune!!!Duster is road legal, but not road ready. Needs tuned better and I don't think it is shifting right.
Bogs down at about 25mph
Is the kick-down linkage adjusted properly?Duster is road legal, but not road ready. Needs tuned better and I don't think it is shifting right.
that looks like that wonderful clay muck... ruhtroh
usually lots of fun gettin' 'em stuck - it's diggin' 'em back out that tends to suck..
I am guessing not. Don't know how ....yetIs the kick-down linkage adjusted properly?
Yeah, you found just the right soft spot and sunk too far to get it out without mudder tires.Yep, much easier with the tractor, honestly that's the first I've not been able to rock it out in this jeep. Probably gone thru that exact spot 500 times kind of surprised to get stuck there
how are the curb idle and timing?I am guessing not. Don't know how ....yet
looks like the muck up here in the corn fields closer to the Connecticut river...Yeah, you found just the right soft spot and sunk too far to get it out without mudder tires.
I did set both. Pretty sure I messed with idle since. Will need to recheck all that.how are the curb idle and timing?
How old is the fuel? Don't waste time trying to adjust a carb with old stale fuel.I did set both. Pretty sure I messed with idle since. Will need to recheck all that.
Not to mention the condition of the plugs if it's just been sitting a long time.How old is the fuel? Don't waste time trying to adjust a carb with old stale fuel.
Should be fine ,. Kept it low and used stabil since I changed the tank a couple years ago. Most of what's in there now is not more than a few months old. Certainly very burnable. I figured I would be retuning through the first couple tanks anyway.How old is the fuel? Don't waste time trying to adjust a carb with old stale fuel.
any other issues? ..dim lights? ..squealing belts?Should be fine ,. Kept it low and used stabil since I changed the tank a couple years ago. Most of what's in there now is not more than a few months old. Certainly very burnable. I figured I would be retuning through the first couple tanks anyway.
No, I really think this is more trans than engine. I need to get it out again and really see what its doing. Didn't want to go far with it today and too much traffic on my road this afternoon to be f'n around with it.any other issues? ..dim lights? ..squealing belts?
