My thoughts exactly!me niether, wow! really makes me wanna change my plans and go electric
They tested a bunch of different types. The OEM 6-blade fixed fan killed 30 HP, slightly worse than a 6-blade plastic flex-blade fan..
I just didn't know it was THAT much. And, as they pointed out in the clip, that's at a modest rpm. At 7,000, its probably a LOT more.oh yea - that's why a lot of racers use the electric units
I wouldn't lose it all together though - get caught in traffic when it's 86 out and eventually you will over heatI suppose you don't really need the fan at normal cruising speeds if you don't live in Arizona? We rarely get more than 80 degrees.
I have had people tell me that with the fan, the 727 and the Ford 9" I am probably losing at least 40HP and probably more like 60 - or more...I just didn't know it was THAT much. And, as they pointed out in the clip, that's at a modest rpm. At 7,000, its probably a LOT more.
at least. they claim it takes 45 hp just to turn a ford 9 inchI have had people tell me that with the fan, the 727 and the Ford 9" I am probably losing at least 40HP and probably more like 60 - or more...
huh - there goes 75 right off the bat then - add in the 727 (which I have to guess isn't a whole lot) and you could make a case that I am making 80 or 90 more HP than I dyno-ed at...at least. they claim it takes 45 hp just to turn a ford 9 inch
how true it isIt only Matters when you get to the Stripe !!!
when I was working as a dyno tester, we normally figured on a 25-35% drop in power at the rear wheels vs flywheel power depending on transmission and type. More power loss in new autos than older ones.huh - there goes 75 right off the bat then - add in the 727 (which I have to guess isn't a whole lot) and you could make a case that I am making 80 or 90 more HP than I dyno-ed at...
I don't remember the exact # but it was just shy of 400@ScampMike what's your rear wheel number
yeah probably a good assumption. here's some numbers for you though.but now I see why the PO had a 100 NOS shot on it - had to make up for what he was losing through the drive train..
so you're probably around 510-520 flywheelI don't remember the exact # but it was just shy of 400
no, but soonyou gettin' outta work early?
and if I were going to race the car I would be trying to "fix" it - but it's just for fun so a few little tweaks maybe but I am not going to chase that dog around..so you're probably around 510-520 flywheel
well, it's 55 here - it must be dang nice out down there!no, but soon
yeah. people get too hyper about numbers. There's tips and tricks to dyno-ing that can lead to big gains easy. For me, I want consistent numbers verses peak numbers. My goal is 550 flywheel and if i continue to follow the combo IQ52 posted, he broke 600 with his. Now, my combo is gonna be slightly different as I'll be running aluminum heads that flow just a tad less than his. so I should be fairly close. Either way, should make for a fun ride. and that's what matters to me.and if I were going to race the car I would be trying to "fix" it - but it's just for fun so a few little tweaks maybe but I am not going to chase that dog around..
hey, side question, how many quarts of Por15/Rust Bullet to do a car? or should I just get a gallon?
start with a gallon - but you'll need more
Yup.. Nice and Frothy Here....well, it's 55 here - it must be dang nice out down there!
yea, I know - and I would never put anyone on ignore - not even you...
they make big screws.....
Old painter told me a trick, screw the hole.
Oh ****.... thinking my wife might be pregnant....
