Stop in for a cup of coffee
This township has an interesting history...
Aston PA was first settled in 1682 as a municipality and was incorporated as a township in 1688 (one of the first townships in Pennsylvania). Prior to 1687, Aston was known as Northley. Edward Carter, who was the constable of the township, changed the name from Northley to Aston in remembrance of his old home of Aston in Oxfordshire, England.
In colonial times, Concord Road was the main road between Chadd's Ford on Brandywine Creek and Chester PA. The Seven Stars Inn, located at Concord Road's "Five Points" intersection, served as overnight quarters for British General Cornwallis on September 13, 1777, two days after the Battle of Brandywine as British forces slowly pursued George Washington's army. The following day, three Hessian soldiers were convicted of plundering a local house (which was across the street from my last house). Two, selected by lot, were hung by the third soldier, and the two corpses were left hanging.
David Glasgow Farragut (first rear admiral, vice admiral, and admiral in the United States Navy, usually paraphrased as saying "Damn the torpedoes, full speed ahead!" in U.S. Navy tradition) frequented the Tavern as a young student in 1817. The Delaware County Odd Fellows were organized there in 1831 and during the 1920s the tavern became a speakeasy. The building was destroyed in 1949 and replaced by a gas station (that is now a Purple Heart Veterans Donation Center). In 1906, Aston became a first class township. The current boundaries of Aston were established in 1945 when the northwestern portion of the township seceded to form the borough of Chester Heights.
So have a question, why does engine idle faster after x pipe install, BUT drop more RPM when put in gear?? Nothing else changed. B4 x pipe, it would idle at about 1200 RPM in gear, real nice running here. NOW it idles 1000 in gear and the more I turn up curb idle, the harder it engages into gear. BUT still stays at 1000 rpm?
Exhaust Scavenging efficiency.
The x-pipe evens out the flow between cylinder banks resulting in more power at low RPM (higher RPM in neutral) but also adds more power in gear so that torque converter slip becomes less and pushes the in-gear RPM down because it is adding more power...fighting against the stall limit.
You need a 3500 stall converter for that cam and engine now that you have let loose the low end power. I had the same problem on my 360 magnum and the 2500 stall couldn't handle the power. So I either had to drop the cam down or bump up the stall.
I chose to drop the cam down since I wanted a cruiser not a track beast.
What a damn good explanation! Thank you. I am going to call the engine builder and ask his advice on a "tamer" cam for that build.
2 for 1 pizza special tonight at the local pizza shop!
How's ya makin' out with the hand?
coming along a little at a time...
I can type with two hands and a little pain...
My movement is getting better, but once in a while it gets stiff again... Constant stretching to try to get the stiffness out...
I noticed that I can start working on my grip yesterday, that's where I really need work... I can't lift or hold anything too heavy and I feel some pain when I try to turn a door knob with the bad hand...
I can still feel some pain where the break was... But I haven't taken any pain pills for it for over 4 weeks...
I've been dragging the last two days from a cold that I'm catching... Sore throat, headache, fever, congestion, light headed sometimes, and low appetite... My kid lost 10 lbs with this cold in the last week, hopefully it will help me loose a few pounds too since I have to put up with the suffering... (trying to look on the bright side...)
Not many cars cruising Duke's tonight, so I went home and took a nap...
It took me a while with my wrist, but I had some nerve damage in my right upper arm causing issues with my hand which I recovered from, but still every once in a while if I'm off kilter or out of a "normal range" it reminds me.
Go slow. Did they end up pinning it?
My wrist still gets stiff, I just keep working it.
I just saw this on youtube...
This guy got back at the bank that was going after him and turned it around on them...
Awesome!!!
No pins or surgery...
My cast is off and the doc says it's a race against time with scar tissue to keep my movement... I need to get the range now or I will loose it permanently... So I' trying m best to keep it moving/stretching..
I did PT for the nerve stimulation gizmo the do, but even though I couldn't move my wrist on my own that girl would twist up my wrist and fingers till I hollered lol.
My next doc appt is in two months... I hope to be using it normally and back to work by then... Hopefully much sooner than that...
I have a work release but a 20 lb max restriction on my hand... Work says I need no restrictions to return... I'm hoping to get it working better soon so I can get back to work...
How long you been out?
Nice to see someone get back like that. I played hell getting ins when I bought this house because it has a pellet stove and a wood stove in the back garage. Quotes were all over the place.
I saw another video where Wells Fargo was serving too many foreclosure notices so they can up the foreclosure fees... They served a guy and his wife a couple of times each and 4 other "residents" for their house - there were only two people living there, but the bank charged them $45 for each of the 8 notices that they served to pump up the fees... :icon_fU:
Good thing the Wells Fargo CEO was forced to resign last fall... They were doing some pretty crooked stuff.... :mob:
All banks are crooked. lol Credit card co's do the same crap in a default. You start getting $400 letters from an attorney.
Kicked while you're down.
