ScampMike
Despicable Damn Yankee
Jesus - that's a new clutch about every 25k... Chinese guy say - sumtingelsewong
sooo.. maybe Chris wore out his shaft..?? ~what!?Is the input shaft on the trans ok? Something has to be causing it, might just be a worn input bearing?
besides all your cash into car partsSomething has to be doing it, Uneven flywheel? Chris what have you changed so far.
yep hydraulic slaveDang, I'm not helping much here. Hopefully the T/O bearing won't be the issue this time. Hydraulic so no adjustment I presume.
YepJesus - that's a new clutch about every 25k... Chinese guy say - sumtingelsewong
Ah ok thanks
Slave cylinder is external on the bell housingI am assuming it has a slave cylinder on the clutch fork?
Yepsooo.. maybe Chris wore out his shaft..?? ~what!?
Sounds like you're doing everything more than right!yep hydraulic slave
Yep
Ah ok thanks
Yep
New flywheel the last time, had the old one turned on the clutches before. Clutch disc, pressure plate, throw out bearing, pilot bearing changed each time. Slave cylinder changed twice. Pivot ball for the fork changed with the last clutch job last year.
jeeeez - you're getting up later and later and later...Good Morning. Here's a nice new clutch for you Chris.
Just a couple days. I actually looked in here before any of yuins were on this morning, but went back to sleep. Glad I did, needed it. Busy last night. Got my tire valves changed, so no more extenders. Ate dinner late, so up later. Catching up on sleep from a lot of short sleep nights early in the week. Yawn. Just got second cup...jeeeez - you're getting up later and later and later...
did you see that "hose thread" was up near 100!!!I would look at the trans to see if something is not right, something has to be doing it the rest of what you did is right. Does it fit tight into the bellhousing or does it have any adjustment for placement?
you're starting to sound like one of them there retired guys....Just a couple days. I actually looked in here before any of yuins were on this morning, but went back to sleep. Glad I did, needed it. Busy last night. Got my tire valves changed, so no more extenders. Ate dinner late, so up later. Catching up on sleep from a lot of short sleep nights early in the week. Yawn. Just got second cup...
Fits up tight, no room for adjustment. I just spent the last hour on the Jeep JK forum. Appears to be a very very common issue among 2007-current Jeeps with the 6 speeds. So far, no one has found a universal/common fix other than to sell it and get an automaticI would look at the trans to see if something is not right, something has to be doing it the rest of what you did is right. Does it fit tight into the bellhousing or does it have any adjustment for placement?
time to sell!! cut and run - you must have about twice what it's worth in by nowFits up tight, no room for adjustment. I just spent the last hour on the Jeep JK forum. Appears to be a very very common issue among 2007-current Jeeps with the 6 speeds. So far, no one has found a universal/common fix other than to sell it and get an automatic
Yeah, i really want too. But i'll have to fix it first. something im dreading with my back right nowtime to sell!! cut and run - you must have about twice what it's worth in by now
sad part is, according to NADA, what i'd need out of the jeep is just below the suggested retail price at the momenttime to sell!! cut and run - you must have about twice what it's worth in by now
oy - like I said earlier - no such thing as a good time for trans issues - but that really adds another level of ughYeah, i really want too. But i'll have to fix it first. something im dreading with my back right now
good morningHey all......
Still working on the closet project........Getting a nice Tan!good morning
Sounds like you are going to lose no matter what. Did every clutch last at least 20K? Fix it. Get another 10K out of it and DUMP IT!sad part is, according to NADA, what i'd need out of the jeep is just below the suggested retail price at the moment
redneck style..??Still working on the closet project........Getting a nice Tan!
