Stop in for a cup of coffee
See you totally lost me. LOL
So others with my combo get higher vacuum readings and I can only pull about 13.5-14 while tuning the carb. Now if I twist the distributor to increase my initial I'll get a higher reading around 15 + which is what others are getting. But I think that Im at about 24-26* initial at that point. Timing I get but obviously I dont get it at all.
Rhoades lifters will help a little with MPG...
I've also been told and read many times on here that you want your total somewhere from 32-36*. So Im not following you with adding more, because that can cause pinging correct?
Detonation will only occur if your advance exceeds the available fuel and you are running lean. It's not about what you add so much as when you add it. More advance just needs more fuel so it can use it efficiently across the curve. This is why it's a balance between A/F ratio and ignition timing to get the acceleration curve optimized.
Racing is about WOT, street driving is about all throttle positions, RPMs and engine loads.
What cam are you running and what is the manufacturers recommended advance curve?
With 9:1 compression and 93 octane fuel, the 360 magnum engine can take 50° total advance if the A/F ratio is correct across the timing curve.
With that piece standing in front of him, why is this guy looking at the cameraman???
Storm rolled through. No electricty. Might as well go to bed.
Lotto scandal....
Mastermind Of Lottery Fraud Admits He Rigged Jackpots
"I wrote software that included code that allowed me to understand or technically predict winning numbers, and I gave those numbers to other individuals who then won the lottery and shared the winnings with me," Tipton said when asked by Judge Brad McCall to explain what he did.
Tipton, 54, said that when he wrote the code, he believed he was taking advantage of a loophole in the random number software and he didn't think it was illegal.
Investigators say Tipton installed code that let the computers work as should on all but three days of the year — May 27, Nov. 22 and Dec. 29 — when they would produce predictable numbers if the drawings occurred on Wednesdays or Saturdays after 8 p.m.
Mastermind of lottery fraud admits he rigged jackpots - news - att.net
Good morning Mike, Yep :steering: Front End Friday is here again and we made it bud:thumbsup:
Pollen from grass and weeds are high here, oak and tree pollen is over, My son is having the same headache's Started here about 3 week ago Mike
honestly think I'm just slightly dehydrated - did some yard work when I got home yesterday and it was very humid out - didn't get enough H2O in me
That will indeed make us tired and go tosleep and not get the water back in us we need, cutting grass eh could be pollen and dehydrated at the same time :poke:
