johnnycuda
JohnnyCuda's 68
Oh you mean these two the ones that are missing?The one on the driver's side. go to the top two on the far driver's side....
Look at the screen caps and what I circled in your thread...
OK so I ran a hot to that and the reverse lights went on yay.
Yum yum
OK I found the horn relay next to the fuse box like you said.Go to page 8-113 in the 68 Plymouth service manual and it looks like the horn relay should be near the driver side kick panel.. or could have been shoved up near the dash or floor?
It looks like it should be near the fuse block somewhere...
Chicken, beef?I just got done catching up... Had some home made fajitas for dinner tonight...
LOLChicken, beef?
So I rear-ended a car this evening.
The other driver got out, he was a DWARF, walked up, looked at me, then at his car, and said, "I'm not Happy",
I replied "Well, which are you then?"
I'm not sure on that. Been forever since I dug into one.OK I found the horn relay next to the fuse box like you said.
I tested it, when I give the black wire "ground" the horn goes off but it does not from the column.
so I took the column apart and found this I believe this part is broken?
I found the spring and the roller laying on the bottom inside the column and I put that back in but I think this wire goes on the back can it be fixed?
Ok the answer is yes it can.I'm not sure on that. Been forever since I dug into one.
i drilled a hole in that copper tube and tapped a screw on the back, connecting that wire and all good horn is Happy now thanks alot guys!
There he goes..................................................................................................................
Do what? leave them cowpatties in the field alone! lolSumlight makes me melt sometimes.......
my wife wakes me up every now and then too..Pain wakes me up.
Swimming with the fishes are you?It was definitely HOT in the shop yesterday, tell you what the pond felt great in the afternoon!
Well... This where "Huey Lewis, and the News.. Stuck with You ...applies"....That's why I live far away from them!
