ScampMike
Despicable Damn Yankee
eeeeeuuuuuuuuuuI dunno...but it gives a whole new meaning to the words "sheep dip"...
damn - I like crudeDamnit I had a picture I staged that was uncharacteristicly crude for me but it wont upload from my phone
I will try again later.
No, try again...it's "baaaaaaaaaah"eeeeeuuuuuuuuuu
It fits really tight. If it flaps , off it will come. Behind a large truck, not much wind. In a vacuum.That's a real risk. I know a lot of guys won't use them. One trick I've heard of is to get the thin plastic disposable drop cloths for home painting and put it over the car and tape it tight using the blue painters tape before putting the cover on.
I trust your judgement. Do what you think is best.It fits really tight. If it flaps , off it will come. Behind a large truck, not much wind. In a vacuum.
Did you really say that.....Karl will tear that apart if Ben doesn't do it first.It fits really tight. If it flaps , off it will come. Behind a large truck, not much wind. In a vacuum.
Geeeeesh the direction that banana is leaning I would take you as a left hander
I know. I worded it with loaded intentDid you really say that.....Karl will tear that apart if Ben doesn't do it first.
Now and then you have to give the hand a restGeeeeesh the direction that banana is leaning I would take you as a left hander
And cover is flannel lined, soft. Used one before. Good cover for a short term solution.Thing is, the back glass is out. So open air to the new rear package shelf, speakers. Not good. "Why don't you put the glass in"? If I wanted to do that, I would not have sold the car!! BTY new back glass gasket. Well, that and other things.
I see having a real dinner again has made you happy!
Karl's gona have a hayday with that one.
Hell, I'm having a difficult time resisting changing the banana color to "flesh tone"...Karl's gona have a hayday with that one.
That's funny right there. I see you are feeling better! Or you're feeling something better!
Speedo gear. Hoppy can probably give you the correct tooth count.OK here is a question for the guru's and if I don't get an answer here I will start a thread. I have a Motorhome with a 440 with a 727. The tires are 7.50 x 17.5 and I want to go to 7.50 x 20inch. What do I change in the transmission to have the correct speed register on the Speedometer?
And where would I get one?Speedo gear. Hoppy can probably give you the correct tooth count.
OMG
