Ddaddy
I'm changing the World... one pixel at a time!
He can tell you that too. He apparently did a bunch of research on them.And where would I get one?
*pounds on counter and chants* do it --do it --do itHell, I'm having a difficult time resisting changing the banana color to "flesh tone"...
You just know he is....*pounds on counter and chants* do it --do it --do it
I'm no guru.. but it would all depend on the circumference of the 20" vs the 17.5" tires. Keep overall height the same, no change necessary. If your going for larger tires, math comes inro play.OK here is a question for the guru's and if I don't get an answer here I will start a thread. I have a Motorhome with a 440 with a 727. The tires are 7.50 x 17.5 and I want to go to 7.50 x 20inch. What do I change in the transmission to have the correct speed register on the Speedometer?
you don't say there Timmy... (I'm starting to worry about you some..)And cover is flannel lined, soft. Used one before. Good cover for a short term solution.
When is this happeningBen are you trying to make it to Daves?
I can come from home .Mike and Wolfie and David....are you guys coming to Daves?
I can never answer something like this with an absolute.. but it may well happenMike and Wolfie and David....are you guys coming to Daves?
planning to. can't leave here til Friday morning. wouldnt put me there til late Saturday. still time for a few beverages! i want to pick up some sheet metal for the Scout in Springfield Ohio so it kinda makes for a good trip..Ben are you trying to make it to Daves?
Are you going to come? I hope soWhen is this happening
Oct 27th 28th 29thWhen is this happening
I will see you in Christmas eve. Don't be late, there is a surprise for you.Are you going to come? I hope so
No whimping out there...If Ben can do it so can you. If I have to haul old Hoppy there you better be there!I can never answer something like this with an absolute.. but it may well happen
Ho Ho Ho ....OH OH OH!!!!I will see you in Christmas eve. Don't be late, there is a surprise for you.
I can't wait that longHo Ho Ho ....OH OH OH!!!!
Wolfie I knew you would champion me to go ahead and post that pic.Excellent.
I could head north first and pick you up.wow - WOW - WOW
