I think mine call for max 75 also. I filled them up to that and road way to hard and had almost the same thing, forget what is on it.
I'll check when on hard tack. On gravel driveway, can't tellDoes the side of the tread touch the road level on both side? That's how you need to get them.
I'll drop it to 50. Can always put it back in, I have on board AirI think mine call for max 75 also. I filled them up to that and road way to hard and had almost the same thing, forget what is on it.
Genius!I did it in the shop then put some chalk dust on it and drove around till I got it level.
What are they on, and 65 is max air p. I would run 40 and leave it thereThat's what I thought but I checked it, calls for 75 psi max. I'm at 65
Oh crap now you've done it.....Genius!
OH OH OH, EGO BOOST!Oh crap now you've done it.....
No, really Hoppy is a smart cookie.
Remember now the middle will be off up off the pavement just a bit till the sides wear.
Doesn't hurt once in a while......now back to work!!OH OH OH, EGO BOOST!
Chalk dust? Just admit that your floor was really dirty!I did it in the shop then put some chalk dust on it and drove around till I got it level.
Not today UBER is in my plans, again found out last night!Doesn't hurt once in a while......now back to work!!
Need Keefers leaf blower again for sure after doing body work in there.Chalk dust? Just admit that your floor was really dirty!
Sorry sorry. I was inspecting the wear to see if it could tell me what the vibration could be caused by. It's the right front, straight axle 4x4. It did this last month. So I put a spare on and then had the tires replaced as they were due anyway. It went away for about 1500 miles now it's back. Tire shop didn't find anything worn during their inspection at the time. And the previous tire was out of balance but it wasn't cupped and I've since checked the suspension stuff myself. This is even a new rim as the last one was bentLol thought we were talking about wear. Can be one out of balance, that can cause "cupping"
MorningGood morning all.
