Morning Hoppy!
If that vac advance can be good, they usually suck either the solenoid is bad or the vac itself prob 50 in parts unless the guy wants a 100 point then it gets crazy, points, cond, lead and the vac advance averages 250. so around 100 except the advance. Actually have four nos ones. That 219 one was nuts last year a lot of interest in it sold fast one guy wanted it and said he would come back for it, gave him a day then put it out again sold in 5 minutes. Nobody rebuilds them. Hope it gets here fast so I can rebuild it.Wow, another steal! What kind of money do you typically have to put in, if there's such a number?
Morning Guys. Those points look like late 50's Hemi. (and HP273)Been on a roll again, just throwing a low bid and getting them. Just scored some nos old mopar dual points for 15.
Have to buy them when you see them. They are hard to get for a decent price.
Yeah I stopped running the Cooper SSTs for that very reason on our farm trucks.Not that this will help but I've seen a model of Cooper tires that tends to wear every other lug, seen on multiple vehicles. So nothing going on in the wheel bearings on that side?
As far as I can tell, hub/bearings spins smooth and straight
its on a Jeep, no, that's one thing i need to do is find someone to spin the wheel lock to lock for me. ive pryed on the ball joints with a pry bar as well as the tie rod ends. Track bar looks ok, not a lot of free play either. I was thinking maybe a warped rotor but beginning to doubt that evenOkay, I had that on my 89 Suburban. Had shop rebuild entire front axle with Yukon axles, limited slip diff. They set preload too tight and bearing on one side only lasted a couple years, should have done the work myself. Spring bushings all good, have you gone under the truck and watched a full lock to lock?
yeah. Was just going to shot gun the whole front suspension but now its bugging me so I wanna knowI'd do that then, I've found a steering gear box that had mounting bolts wallowing out in the frame, wouldn't have seen that if not for being under vehicle and watching several back and forth turns. Good luck.
Oh crap now you've done it.....
No, really Hoppy is a smart cookie.
