Good Morning All!
Great all that hard work paid off.No, we didn't need it as had a very solid offer that was 10K over asking. Could have still had the open house but first offer would have expired, then there were the chances that it wouldn't appraise if it went much higher so we accepted it. Now I've got to get my Duster out of there or it "goes with the house".
N ice to here it worked out now get off your *** and get the car rolling!No, we didn't need it as had a very solid offer that was 10K over asking. Could have still had the open house but first offer would have expired, then there were the chances that it wouldn't appraise if it went much higher so we accepted it. Now I've got to get my Duster out of there or it "goes with the house".
I saw it was like 88....that's mild compared to here.Man I hope the weather breaks for Carlisle. It always is hot there but this would really suck!
I'll check my parts pile this evening, I may have one or two left from one of my chargersThis is the one. It also works the key buzzer. Many other places show they have the right part, but then you see it is different. Thanks Keith for the help!
NOS MOPAR 1971-3 B C & E BODY HORN RELAY ALL | eBay
problem is with the heat index over 105I saw it was like 88....that's mild compared to here.
That's warm, not quite the 115 we've been having.Pr
14 foot ceilings.Tall enough for a lift or three?
Should just slide in pretty easy. I would not ne prying on them to hard. They the right bars?Yesterday I got the A arm mounted and then could NOT get the torsion bar in. So went to Drivers side where the A arm wasn't even connected to the frame, couldn't get that one in either. I know I have them on the correct sides. So today I go back with a bigger pry bar. I have adjusters backed all the way out, may remove bump stops even though I don't see them contacting.
This may sound dumb but could you try flipping the torsion bars around and seeing if the other end goes in easier? Not sure that it matters but just an ideaYesterday I got the A arm mounted and then could NOT get the torsion bar in. So went to Drivers side where the A arm wasn't even connected to the frame, couldn't get that one in either. I know I have them on the correct sides. So today I go back with a bigger pry bar. I have adjusters backed all the way out, may remove bump stops even though I don't see them contacting.
Oh yeah make sure the hex is lined up right
They should be the ones for it. Weird. Hey when you backed off the adjusters did the hex part come loose and shift? Could be rusted in had that on the dart.
