Stop in for a cup of coffee
A Good Morning shout to Memike and Mitch.
Have a Great Day!!
so I've hunting through my bookmarks, I know I had the 64 electrical diagram saved somewhere. I lost my hard copy of it. :BangHead::BangHead::BangHead::BangHead:
Might put that on later. Might reflect the sun off of my sexual solar panel! (bald spot if you did not get it)
My Mopar and print them all out.
found it on there! thanks
Use that meter yet? Like it?
not really. Just tried it out on my jeep as a test to make sure it at least functioned somewhat. Probably use it extensively over the long weekend as I wire this thing
Chris I thought you went with a painless harness?
No, I was going too but after reading that you still have to splice in the mopar connectors and such, I couldn't justify the cost, awfully expensive to not be a direct plug and play. If it was plug and play, I would have.
The tin foil isn't working.. I still hear voices..
Here you go they used to make them might find one on e bay.
Bald spot....I thought that was from pulling his hair out???
I posted those connector kits. Your wiring ok and not brittle?
the harness in the polara is toast. melted connectors, melted insulation, not much to be salvaged.
And I ordered one of those connector kits, supposed to be in Friday.
I did manage to find an original engine harness to bulk head in Arizona, its supposed to be here Friday as well. it looks to be in good shape. Just wish I could find the interior and rear harnesses
Did you order a crimper it is special.
