Why pull it in? I thought it ran. Can you not drive it in?!
Should have tagged him to get an alert - @toolmanmikeUgh.
here's a shortcut Stop on in for a cup of coffee
Got it.Should have tagged him to get an alert - @toolmanmike
Hahaha I have my moments
Your forgiven....nice deck!!I have been sooo busy.....ignoring my Mopar friends......sorry....
Got all the arrangements made to go pick up that guys car?Hey Tim and Mike....
Back from a loooong coffee time.
Ouch!Got all the arrangements made to go pick up that guys car?
Mission accomplished. What a PITA.Think I will get out and put my 2 porch posts up that are done.
Looks good though!Mission accomplished. What a PITA.
The metal under the porch roof has almost half inch deep pattern. Rather than shim above it, they crushed it. Plus the bottoms sit in little divots that are not equal...Making it nearly impossible to get good measurements. The front 'beam' is 3 2 x8 or 10s sandwiched together and had almost no flex. So I attached the posts where they were and they didn't touch the concrete. Was able to pull the metal loose and get some spacers under it though. So, in the end they are supporting and metal not crushed as bad as it was.
Probably won't get back to the corners till after the hurricane remnants clear through here...Not that it matters a whole lot. I never realized before I started working on it, that it does nothing to hold it down, only supports it up.Looks good though!
I originally thought they were poured into the concrete and had rusted off, I am pretty sure that is how the handrail was out back that I removed when I built the deck. But these are just recessed enough that they cant be kicked sideways. Of course that resulted in them rusting cause they were sitting in a pool of water every time it rained. I might fill those pockets with epoxy if I have any play when done. Though it won't matter for rust anymore since the stubs I welded on are stainless.Probably won't get back to the corners till after the hurricane remnants clear through here...Not that it matters a whole lot. I never realized before I started working on it, that it does nothing to hold it down, only supports it up.
Looks good.Mission accomplished. What a PITA.
As long as there is enough wegiht and rigidty it , it obviously hasn't taken off, yet...Probably won't get back to the corners till after the hurricane remnants clear through here...Not that it matters a whole lot. I never realized before I started working on it, that it does nothing to hold it down, only supports it up.
Sounds like a plan.I originally thought they were poured into the concrete and had rusted off, I am pretty sure that is how the handrail was out back that I removed when I built the deck. But these are just recessed enough that they cant be kicked sideways. Of course that resulted in them rusting cause they were sitting in a pool of water every time it rained. I might fill those pockets with epoxy if I have any play when done. Though it won't matter for rust anymore since the stubs I welded on are stainless.
Yeh, not worried about it. Only a 6 ft overhang. Just always assumed... I mean when you build a deck they want hurricane tie downs...Looks good.
Iif we were in tornado country might be a 'nother story.
never seen any done with lead. If I add epoxy its just to fill pockets. Still not holding anything down. Only way to do that now is L brackets (ugly) or drill and sink longer posts. Not going to happen. If it gets ripped off, insurance can pay a contractor to do the revisions on the next round. LOLSounds like a plan.
Direct in concrete is good. I really like when its in a lead anchor - 100% rustproof!
