Stop in for a cup of coffee
Finished that mechanical distributor yesterday had to get creative locking it out and thank god for dremels. Will post a pic later.
Yeh, no doubt...
My ignition key looks about same as what they pictured, but trunk doesn't have the extended top for the ring to go through. The opening is cut from the round part
Tried the ones from the pop would not fit in. Just cannot find a set locally just have the original set need a spare set.
Morning Gang !!! I might have some Mopar blanks from my supply of keys from my Curtis Key machine. I'll look , when I go out to the shop...
Locksmith should have a book with a code for the correct keyway. Might find a functional blank that way even if it doesnt nlook OEM correct.
I should get a new set cut as well.
Isn't there yet another style key that was used 67?
I've thought the one on the top left and top right most likely the originals.
Those are same as mine. I got blanks from member @gunbunny at Carlisle. I think $5 a pair. I got mine cut at Ace. He can cut them too, but did not have machine there.
I have a neighbor that is a locksmith. He re pinned the tumblers on my GTS so the doors matched the new ign switch..Then I cut spares, on the blanks I had
I looked, Only brand X keyblanks left over. Probably already cut all the Mopar blanks, Sorry...
