Stop in for a cup of coffee
Well OK.. A guy goes into a zoo. The only animal in the zoo is a dog. It's a shitzu..
I think it will blend in better after it's painted black.
That clown orange says look at me, I am not year correct but i am still here weeeeee
Male bovine are bulls or steer, not cows. :poke:[/QUOTE]
Don't think steers can think that way anymore.
Well the weather was so misty/ rainy here, but warm. So I decided, rather than mess around with the A100 seat brackets, outside. I would pull in the D250 Cummins and fix the fuel leak. Started leaking above the fuel filter at the fuel heater adaptor. After some research last week, I found out that it is a fairly common problem. The o ring above the fuel heater gets brittle and leaks. Yup. sure nuff... Easy fix tho. Fuel filter off, Fabricate tool to pull threaded adapter off, Reassemble with new o ring and fuel filter.. Time for a Chocolate Ice Cream Sandwich. I keep em in the garage freezer, with the Deer meat....LOL
I think this is the original distributor the car left the factory with.
It has is 67 dated, if that is what the 67 means
