Ddaddy
Just doing what I do
That’s the same as was used on the ‘69.
On my ‘69, it’s a hangar that screws onto the fire wall and hangs against that indent...
My 71 has a clip that slips over that pinch weld. I've never seen them for sale though.
Interesting. Maybe there was a clip on version and somewhere around '69 they went to the new style.The ‘69 Barracuda uses the same hanger that my Dart uses...but the ‘68 doesn’t use one at all.
LOL. When you get a chance...Now Im curious after Tim posted that link, but Im to lazy to go look at my car... I swear they are a clip style and not screwed on..
1967 was an odd year.66 has the clip on style....
Since you needed to know I went to the garage. I was 50% correct. I have a push on style on the passenger side and a screw in style on the drivers side. Im not entire sure if the passengers side is OE but it was on there when I bought it and looks like it was on for a long time. I can post pics later if you need.LOL. When you get a chance...
I'm searching through FABO right now for pics. I'll start a thread later or tommorrow.
I've also looked through an older Laysons and Year One catalog. I swear I saw a clip on one somewhere. I actually thought I might have one that came from this car. But the photos show clearly there wasn't anything there when I got it.
Thanks. I hope it wasn't too cold out there!Since you needed to know I went to the garage. I was 50% correct. I have a push on style on the passenger side and a screw in style on the drivers side. Im not entire sure if the passengers side is OE but it was on there when I bought it and looks like it was on for a long time. I can post pics later if you need.
I guess I'm confused you are working on a 67??1967 was an odd year.
in more than one way!
Yes.I guess I'm confused you are working on a 67??
Well I'll go look at mine.Yes.
My car is a '67. It was originally equipped with a slant six.
Car stuff.
Worked a little more on the car today. There's a couple places where the wiring harness had factory supports that are missing on my car. This surely caused some strain on the field wire and the ignition wire. Hey, ignorance was bliss.
Now I'm looking for any information or pic on how the wires were retained, especially the main harness from the firewall to the brake fail switch on the frame rail.
It looks like there should be a coated metal retainer on the firewall-cowl lip. I'm hoping this is a clip on? If so, ever see one for sale?
You can hear them going but not much coming. .
Car stuff.
At least with my current repop harness, it could definately use the support to take the strain off the connector at the ballast.
Time for this cat to hit the hay.
