Yes. Not cheap but I wouldn't put cheap filler under an expensive paint job.
Agree, very ugly, they are protected here, they keep mother nature's floor clear of dead animals.We do have Turkey Vultures. Ugliest birds on the planet.
Those were made by Appliance. Their cheaper line if I "remember" correctly. Damn that was almost 50 years ago. Heck, I can't remember what I did yesterday.
I almost ordered a new Mirada back in the day. Cool looking Mopars from a different era.
I didn’t think it was all that bad price wise.Yes. Not cheap but I wouldn't put cheap filler under an expensive paint job.
Yep, the lowest there was back in the day. I do remember them.Those were made by Appliance. Their cheaper line if I "remember" correctly. Damn that was almost 50 years ago. Heck, I can't remember what I did yesterday.
Would you epoxy primer first and then body fill? Sand and then high build primer?Yes. Not cheap but I wouldn't put cheap filler under an expensive paint job.
I didn't see the price but last time I bought some it was about 80 bucks a gallon.I didn’t think it was all that bad price wise.
That's the way it should be done but I've done it and most body guys just put it over bare metal and it works out just fine. and then epoxy over the filler.Would you epoxy primer first and then body fill? Sand and then high build primer?
I wanna do this right the first time…That's the way it should be done but I've done it and most body guys just put it over bare metal and it works out just fine. and then epoxy over the filler.
Na Na a nana lightening!I hear thunder.
Straight through, zero suppressionView attachment 1716305244 Need some Thrush mufflers for those headers? (tin cans)
The Hush THrush were chambered but still tin cans.Straight through, zero suppression
Between those and the Hookers, made the 2 bbl Teen sound like it had a Purple Shaft in it and got that ? from countless passers by.The Hush THrush were chambered but still tin cans.
I miss the original purple horniesBetween those and the Hookers, made the 2 bbl Teen sound like it had a Purple Shaft in it and got that ? from countless passers by.
I tried them on the Twister. Headers and torsion bar cross member put a X on that ideaI miss the original purple hornies
So install them farther back…I tried them on the Twister. Headers and torsion bar cross member put a X on that idea
8 dollars for a muffler. What do you expect..I miss the original purple hornies
