These are your choice of words are they not?
Simple question gets a simple answer: No they can’t. These are the heads you are talking about:
A factory assembled oem 302 head, pulled from a box ready to install. So no, Installing a set of 302 heads will not push a 3400 lb brick into the 11’s.
And, these are your choice of words are they not?
I agree. So no porting, no valve size changes, no nothing. As you stated in your response to me, what people are doing or not doing is irrelevant.
No moving the goalposts, no tweaking the premise, changing the narrative, rewording your question.
So, put those 302’s on that small block, stuff it in your 3400 lb brick and prove to the world that they can push that heap into the 11’s down the 1/4.
Can they or can they not make the power to push a 3400 lb brick into the 11's is the question.
Its a simple Yes or NO.
What people are doing or not doing is irrelevant.
