Tricks? Like magic tricks....... You mean illusions or just smart engineering. You're just trying to make excuses for why they can and you believe I can't. All the airflow they need is right there in those tiny heads but you need to be smart enough to extract it. Imagine what they could do with more compression.......more lift......more carb...glad I'm not restricted in those areas.......
No games just simple logic. Either the heads can flow the air it needs to make the power or they can't. Which is it can they flow it or can't they. Yes or No.
If you say Yes then we move onto the next question. If you say No then you are effective saying PHR, GTX JOHN and every Stock Eliminator racer is a liar.
So, which is it?
