GTX John he's a member of this forum I believe.So 11.8x at 109 and 4K pounds. Now what class is he running?
maybe he will chime in.
He said this too:
We are very partial to the 302 heads both for power and mileage by a wide margin!
What!?! A serious class racer likes 302 heads? Who could have thought.
But some how you guys assure me they cant make power........I know who I'd be sending my heads to if I wanted them ported
Hope I don't get you into trouble John.
I'd like to see the torque curve, the Streetmaster could have made a real tire fryer.I believe ANY small block and big block mopar head from 1964 and up can be worked with and made to perform to a point. 302's are no exception, they can be ported and larger valves installed which will greatly improve the performance compared to stock. But some heads allow the performance to go beyond other heads, or have a much higher ceiling.
- Back to the point of the intakes (what the thread was about), I don't know of anyone that would be excited to bolt on a streetmaster and lose horsepower. And that was the topic, hp.
wasn't that the intent of the streetmaster? Really it was designed for stock exhaust, cams, and heads, with highway gears. I ran the Holley street Dominator on the low dollar 318. The factory cast 340 intake went 1.5 tenths quicker than the dominator even though the cast had an adaptor for the spreadbore to square Holley carb. Amazingly, the street dominator 60 ft the same, though.I'd like to see the torque curve, the Streetmaster could have made a real tire fryer.
Why would you port them? They already have all the airflow you need!
Is this what I've reduced you to? A meme that asks silly questions in the hope of trying to salvage some pride after it became painfully obvious that a 302 head can make all the power I need? Even after you spent numerous pages avoiding the question in the hope that you wouldn't have to concede and now you want to do it all again.
I love that fighting spirit!
He said this too:
I happen to like checkers and I'm pretty good at it too...If that’s all the power you need take up checkers.
There you go hallucinating opinions again. No data, math, science, or experience to back it up. But at least we know 13s are fast enough for you, glad you've already reached the top of your mountain.
You mean this junk:
1964 Valiant 3300 pounds with driver
360 .70 over with 9.6-1 comp
Ported 302's 62 cc
Performer manifold with Edelbrock 600 carb
Crower 271 HDP cam 1.6 rockers
1.5/8 headers and 2.5 inch exhaust
904 TA 10 inch converter
8 3/4 3.73 gears
M/T 255 street radials
You missed this bit 5 posts later: Car went 12.63 @ 107 mph on a 1.853 60ft.
As you can see I use only top shelf big dollar parts that only the Stock Eliminator guys would use.....Even funnier was a leakdown test showed 1 bad cylinder and another heavily scored.
Always with the excuses... Bad cylinders, scoring, misfires, bad suspension..
I think you should stick to shuffleboard. You screwed up your porting, making the car slower, and then brag about a slow car you can't even build well enough to keep all 8 cylinders alive. Hahaha. I'd feel bad for you if you weren't such a drag.
The guys you worship are far faster without all the piss poor porting, and despite the fragile nature of a stock build, they even manage to keep their motors intact.
Pathetic.
Even if the car ran 10's you would write the same garbage because that's who you are. You still didn't answer the question......
If only they'd tossed the SM back on at the end......then We'd REALLY know sumpin'..
What’s the big deal, you haven’t answered a few question ether!Even if the car ran 10's you would write the same garbage because that's who you are. You still didn't answer the question......
I'm not familiar with the small block street Dominator, but I do know the 383 street Dominator makes a little more on the top end than an RPM.wasn't that the intent of the streetmaster? Really it was designed for stock exhaust, cams, and heads, with highway gears. I ran the Holley street Dominator on the low dollar 318. The factory cast 340 intake went 1.5 tenths quicker than the dominator even though the cast had an adaptor for the spreadbore to square Holley carb. Amazingly, the street dominator 60 ft the same, though.
I don’t believe a word of this.You mean this junk:
Ported 302's 62 cc
8 3/4 3.73 gears
You started this troll thread. The question was whether 20hp was worth it for an intake swap. When everyone basically said "yes, to say otherwise suggests brain damage", you got in a huff because that's who you are. A troll who justifies their slowness by claiming "but I did it cheaper" - yet for the same cost and amount of work, you should be clicking odd consistent 10s.
You cosntantly pose cryptic questions
100% Hogwash!
It's worse than the original Edelbrock Torker. If that's even possible. Both good for doorstops.View attachment 1715829485 View attachment 1715829486 Not even that big at the head flanges. And even smaller at the runner entry inside the plenum.
