They look like a bolt in "better than nothing" connector. I don't like the idea of a round tube providing the strength. We all know what torsion bars do. LOLI fail to see how the bracing on those will really contribute much in the way of rigidity.
Homemade and handy and as strong as the Golden Gate Bridge!Bought stock for $25. Overlapped rear frame nice and welded to rear floor pan also,
US Car Tool ones make it look like it left the factory that way. Nice stuff for sure.These are really nice. A buddy just did a set in his Duster. A buddy of ours that welds a lot came in and knocked it out of the park.
Below is a link to just the connectors alone.
There full kits are really nice as well.
67-75 Mopar A Body Frame Connectors
This isn't my car but where I got the idea from... I think it paints it a little clearer..
Here's a vid of US Car Tool install. There are many others. The guy is building a charged small block Valiant. Been following his videos. Pretty good stuff.US Car Tool ones make it look like it left the factory that way. Nice stuff for sure.
Yep. The only thing you can do is categorize it. Which is cheapest. Which looks the best, Which is easiest to install. But the debate is always about which is strongest. Who knows and how could you test it unless you are an engineer in a lab.This subject gets argued every few months! with more determination than discussing oil!!
Those of you making your own, what are most using? 2x3? What thickness? I assume 1/8"?
Maybe .03 % of our members can pull the front wheels . So I am not sure how important ultimate strength is .
It’s fine to mention the “DIY” alternatives but it’s not the only answer.
Not everyone wants to have a Home Depot fabrication job under their prized car.
It’s not just pulling wheelies. It’s the load applied to the chassis through the front spring mounts and all the suspension points. All that load is transferred through the floor and up the A and B pillars.
That’s why a hard hooking flexible chassis will crack the B pillar, break the side windows out and start moving the A pillar around.
BTDT and it ruins the car.
OK, another alternative. When I bought my frame peices I had them cut to exact lentgh $25. How much would a bodyman charge you to weld them in? He wouldn't have to weld them to the floor like I did.Still stronger than bolt ins IMO . Bolt ins $500? It wouldn't hurt to ask.
Hope that wasn't directed at me. In the end I thought they came out good.
