I had a '69 Dart strip/street car with a 440/727 combo in it. The car was barely street legal and was mostly used on the strip. The fenderwells were already cut out so I put a set of Hooker 2" fenderwell headers on it. Here is what I thought about them:
1. Ease of engine/trans maintenance - spark plugs, starter, trans shifter and kick-down linkage etc all easily accessible.
2. Ease of installation.
3. No burnt starter, plug wires or trans shifter cables.
Dislikes:
1. Like others have said, I experienced tire clearance issues too. I had to run 14's on the front. Didn't experiment with different wheel backspacing to gain more clearance (wasn't smart enough at the time to think of that!).
2. With the smaller 14" front wheels the header collector flange would sometimes catch on the back edge of the trailer/ramps when loading/unloading the car on to/off of it
3. Brake lines coming off of the master cylinder were real close to the header. Had to do some creative bending and rerouting of the brake lines. Have seen where others have installed different master cylinders with the outlet ports on the right (vs stock left) side.
4. When making a 1/4 mi pass I had a tendency to keep my left foot firmly planted on the floorboard to the left side of the brake pedal. I raced in sneakers and there was no carpeting so by the end of the pass I would get a "hot foot"!
Ma Mopar didn't do anybody any favors with all of the junk (torsion bar, steering column, starter, clutch cross shaft, etc) on the left side. Would have been a whole lot easier if they had put the starter on the right side, but that's a fantasy. I do like the idea of the partial under chassis/fenderwell header (a couple of tubes inside and a couple of tubes outside the frame rail) that Brad4406 and mischiefdart mentioned. I have only seen them with big primaries on full blown race cars and have not seen them for an A-body but I do like the idea of them. Might be worth investigating as it give you the best of both worlds. Which ever way you go I also like the idea of having your headers ceramic coated to reduce radiated heat - won't have to worry about overheated tires, brake lines or "hot foot"!
I wouldn't ever try and talk any one into using fenderwell headers, ever.
I've got mixed feelings about going with fenderwell headers. I'd like to hear from you all's about why I should go with them. My reservations lie with cutting the inner fenders and taking away from the front end stiffness, structure, etc. This car is to be street/strip driven with 75% street time. How do I handle running the exhaust under the car and out back since I'm using frame ties? Wouldn't this cause the pipes to be run lower to the ground than normal?
I heard somewhere along the lines in someone else's thread that they were only good to like 450-500 hp. Plus I was hoping to get somewhere near 2 to 2-1/8" primaries...
the cons always outweight the pros from my prospective...
Cons....
A) restricted tire space
b) almost impossible to get anywhere close to equal length tubes for max performance
c) some tubes end up being almost 48" long....way too long for optimum.
D) header heat and interference with master cylinder and brake lines ... Major pia
e) ground clearance is a concern with the tubes having to fit under the frame-rail to reach the collector
f) major surgery required to both of the fenderwell aprons
pros....
A) starter and clutch linkage is easy to get at.
Tti's under chassis headers are no big deal to drop in....just slide out the torsion bars for easy-peasy installation.
My reason is I don't want to pack 8" of **** into a 4" hole. I want the ability to work on my car with headers in place if possible...that's why I'm trying to stray from the tti's...
You only need the 6 ft cable.Not trying squable about 2 ft.
The primaries on my tubular parts automotive fenderwells are 34" x 2" according to the manufacturer's literature. Mine have the street collectors as they were also available without the flange.
