It is I sent it to him.
What gear set will work and fit in my 73 8 1/4 housing sir ??it seems as if you have a similar issue. the carrier ratio breaks are 2.45 and down (numerically) and 2.56 and up.
so if your 2.71s wont work with that posi carrier with your ring/pinon then it must be the 2.45 down unit and will never work for you if you want 2.56 and up ratio.
Never opened the 7 1/4 up, just the 8 1/4 like we talked about, the open carrier I took the gears off of and put them on the sure grip I got from you, we thought the sure grip was for the tall gears is what I was thinking... never talked about a 7 1/4 .. swaped to the 8 1/4.No he wanted to use the high ratio gear for his car it is a brand new trac loc. His new 8 1/4 carrier is prob wrong for it. I thought he had the right carrier he did in 7 1/4
Thank you two for all the time,Help and info that I have learned here.
I can't say it enough but this has been a head banging thing to deal with..
You two members have sure stepped up and helped this old guy on the hill this morning..
