rfairba340
Active Member
will a posi out of a jeep 8.25 work in my 73 8.25
ok thanks, I pickup one out of 94 Cherakee for 100.00 havent opened to see whats in it just know its a posiNo but a track lok will if it is a housing lower than 2.45
3.21 open 8.25 73 DusterWhat ratio is in your current rear?
ok, I took my donor rear apart it has a 3.55 ring and pinion but the carrier looks like an open with spider gears, but both wheels turn same direction so is this considered a trak loc,and if i understand this 3.55 carrier should bolt right in.I did not remove the tone ring on mine. Some people had to because it hit but mine did not hit so I left it.
