Meme, the tracking # is in paypal.
I will send them back right away if I don't need them Hops Thank you again pardHey I added a shim pack and the crush collar. If you don't used those side shims I sent you do me a favor let me know they are kind of hard to find.
I made my own tool for setting it up and it works perfect, went to Ace hardware and picked up a 3/4 in. pipe and two ........ Let me find a picture of it, it works great ..I picked up an A body 72 8 1/4 with a 321 gear. I've read the break is with the 271 gear set between the cases with the 271 using the "good" case. I have a 271 B body 8 1/4 of which I gutted to use the 321 ring and pinion in. I was going to just swap carriers but I've found that the A body rear uses the smaller bearings and races so I just bolted the ring on the B body carrier. I didn't realize there was also a difference in bearing size even though the cases appear identical except for the width. surprisingly, the pinion bearing and the crush sleeves are the exact same lol. the FSM shows a wrench to adjust the side to side play for the carrier instead of the long tool that slides into the tube. just a tid bit of info to share. I still have all the adjustments to make before I'm able to claim victory.
OH !! Ok I will gather anything from that and bag'em and send them back my friendNot the stuff coming the others I sent you if you do not need them.
I would sure take it ! These A body housing are getting hard to find, and I think they are the best kept secrete if you ask me for upgrading from the 7 1/4, Hops will agree with me on that .I wish you were closer Mike I would just give you this A body rear I have , I bought it for 60 bucks complete, just for the gears. I have no use for it lol.
Where are you at?
I agree, these 8 1/4 are used in trucks and Ramchargers, so ! I think that putting them in our lite A bodies will do great even with 350 HP and driven daily or at the strip for some fun safe racing .Never understood why people do not like them they stand up pretty well on the street.
Well 1970-dart !! You saved my a$$ here sir This set of gears and pinion you sent me set up and back lash is smooth as a silk Man on the hill is a happy man this morning The gears you posted fit and worked with the sure grip that @halifaxhops sent me to fit in my 8 1/4 This thread should be very helpful for members to look threw doing an 8 1/4 rear end wanting a sure gripall good buddy thats what we are here for and you would ( and have done) the same for others
