awesome job and great pictures ...where did you get the fire wall block off plates I need some
So the top end is torn down. Have not had the time to take the oil pan off to look at the bottom end yet but I don't foresee anything surprising. One of the freeze plugs at the back of the block was leaking and there was starting to be a thin film of oil on everything. The clean up begins.
For the most part, things looked OK for an older build. There was no real damage to speak of, just a bunch of carbon on the valves due to the seals being shot. I had thought the cam lobes might be toast but it was just normal wear. Some of the rocker arms had some galling from the tops of the springs but nothing major.
Learned a few things about the internal parts that I was not sure of. The block is .030" over and has Speed Pro 7035p pistons in it. They are .018" out of the hole like stock. Gasket looked like .040" maybe but I'm not exactly sure. Has head studs. The inside edge of the deck was deburred. I was not sure if the lifter galley was tubed but it's not. Might do that for the rebuild. I could probably clean things up with a hone, put new bearings and rings in the short block and it would be good to go again.
So despite the valves being all carboned up, the heads were OK. Again, the main culprit was the old teflon valve seals. The little tension springs that keep them tight against the stems were all gone so they were leaking bad.
Consequently, the valves were a ***** to get out. The valve locks were truly locked. I had to whack the valve tips pretty hard a couple of times to get things loosened up. The springs are stiff, took a lot of muscle to hold them down to get the locks out. I am more used to late model OE valve springs which are pretty wimpy compared to these. These springs are not even that burly though, it's just a Mopar .557" cam.
Intake valves are 2.02" but I had the idea that they were larger. No porting in these heads, just your basic late '70s-early '80s 810 casting W2s.
So the end result of all of this is still up in the air. I spoke with Brian at IMM about how to proceed and he suggested I go with his CNC/RHS heads. He said they could support 550 horsepower with a 4" crank, even with a dual plane intake and a hydraulic flat tappet cam. I was surprised to hear that but it sounds good.
There is a part of me though that wants to rebuild the engine as it is and see what it can do with everything fresh. I have to think some basic head porting, a cam, a better converter and a change back to a 4.30 gear would get me in the mid 11s no problem. I could re use the valve train parts, crank, rods and pistons which is obviously a big cost savings. It's hard to deny the benefits of the 4" crank in a street car though since it's basically a drop in and relatively inexpensive. Decisions, decisions.
Anyway, here are some pics.
Here's the right side head as removed.
This is chamber #5 with the valves out.
Here are the valves from #7. These valves look like the ones I used to take out of older cars when I was working.
These are the teflon valve seals. The larger spring retainer that keeps the seal on the guide was there but the spring that keeps the seal tight against the stem were all gone.
This is cylinder #2. These are Speed Pro 7035p .030" over pistons, .018" out of the hole.
Pic of the witness marks on the underside of the rocker arms on cylinder #8.
Shot of the cam.
More to come!
I always liked tuning what I have in hard parts. That way you have a known reference, and can reuse the good known parts. ( I would call virgin W2 castings, " good parts"...). A improvement, probably could be done on the M.P cam. If you like the cam, run it,) You have a lot left in that combination, I.M.O.. Maybe others will chime in with W2 combo's , or start a thread in small block tech forum .A good valve guide/ seat centering, would work wonders for starts.
Where did you get the aluminum bumper brackets?
Just food for thought, the Walbro GSL-392 pumps have been getting a lot of attention lately. They cost around $95.00 and should pump enough for your application. The only reason I bring this one up: low cost and quiet. I run an Aeromotive and it's loud IMO.
I looked into the Walbro, it is high on my list of options. That particular pump seems like it would be easier to mount than a standard vertical style pump. Which Aeromotive pump do you use? In tank or otherwise? In tank is usually a different style pump altogether and is generally submerged in liquid which I would think would help to dampen vibrations.
Frankly, the more I think about it, I really don't want to deal with installing an in-tank pump. The main problems I see with an in-tank pump in our cars are with the tank itself. A body gas tanks are a little snug in the front up against the trunk floor, was thinking it might be a PITA to run all the lines from there depending on where you mount the pump. You can cut out a section and make a lower mount for it but that's a lot of extra work. The tank is too shallow towards the back so you couldn't put it there. If it's in front and you had low fuel you risk uncovering the pickup on the hit. You'd need a baffle which I don't have in my factory tank. Guess that's why guys use aftermarket tanks in that situation, takes the headache out of it and they usually have baffles installed.
I need to get under the car and look at it. Maybe if I stare at it long enough I'll come up with a solution.
Just a few quick updates.
Dropped a block off at the machine shop for initial inspection. I've had this particular block for several years. I hadn't looked at it too closely since I bought it but outwardly it looked OK so I went with that one. Currently waiting on an order from Hughes Engines to arrive which includes a set of main cap studs. Once I receive those, I'll take 'em over to the shop so they can start the machining process.
I ordered a crank from Bloomer Performance. It's a 4" stroke with 'generic' 2.100 rod journals. This configuration allows me to run a *gasp* Chevy 6.125" rod with a .927" wrist pin. Diamond makes a shelf piston for this exact combo which is what I based ordering the crank and rods on. Not sure what the final bore or deck height will be so I have to wait on the pistons until that is known. If something ends up really wacky, Diamond will alter a set of pistons pretty cheaply so it should all work out pretty well. Aiming for zero deck height and around 10.2:1 compression ratio.
Ordered a bunch of other stuff as well; Kevko oil pan and pickup, fasteners, gaskets, freeze plugs, timing chain and related parts, a set of Hughes 1.5 rocker arms, a flexplate and on and on. I think my credit card is on fire.
I will be ordering some engine tools this week to add to my ever-expanding collecton; cam install/degree tool, deck bridge, pushrod checking tool, ring compressor and filer and a few other things I can't remember at the moment.
I want to mention that buying all these parts in rapid succession definitely makes me thankful to be in a position to do so. I question the nature of these things sometimes but building engines really is a noble exercise that produces tangible, lasting results and experience. No one can argue with that!
More to come.
Hey man don't worry about the Chevy rods. I run them too! Lol. Cheaper bearings is how I look at it.
Text heavy, easy to do. Look for at least .060",on every spot on mockup.Just logging some things here, don't mind me.
Spoke to the machine shop the other day, the Bloomer Performance crank showed up there. I have not seen it yet but the machinist said it appears to be a quality piece, even if it is Chi-neezy. He actually spoke with Rod Bloomer to confirm some questions which was cool.
We discussed a few things on the phone. The mains in the block will need to be honed, they were a little too tight with the studs torqued down. Not sure how much it will take to clean up, hopefully just a wee bit to make 'em true.
He suggested using King bearings for the mains and rods to which I said OK. He found that they were superior to Clevite (more expensive) because they were of more consistent thicknesses. He had several experiences where the other brands were off by .002-.003" measured in various places and had to sort through boxes of bearings to find a good set. Sold me.
So apparently the block had been honed at one point and the bores were about .005" over stock which means it will need to be bored and finish honed to 4.070". He will be using a torque plate, I gave him the head studs to use with it when I dropped off the block. Obviously the goal is to get things as true as possible and using a torque plate is the way to go. Wish I could have kept it stock bore but oh well. Can't imagine there are many factory 4.040" bore 340 blocks out there in 2015.
Deck height is still up in the air until he has the pistons and rods on hand. Compression ratio with the Diamond pistons is based on the nominal .018" @ 9.6" d.h spec., the hope is to achieve zero deck to get around 10.3:1 C.R. The machinist said he generally measures deck height at the 4 corners unless asked to do all 8. We decided it was probably not necessary unless it was really out of whack at the corners. This is a pump gasser for sure though.
My initial plan was to get the block back home, measure deck height myself and bring it back to be surface cut. I decided it would be better to have him do the measurements and make whatever cuts are necessary. He's got the experience and tools to do the job correctly the first time, I can't really afford to screw that up. I'll tackle that on the next build up. Will also save me some money not having to buy tools and save the hassle of carting the block back and forth. There will be plenty of other measurements to take and verify during assembly.
The pistons and rods are on order. I spoke to Brian at IMM just to confirm the pistons I chose would work with his heads and he said they would be great. I let the machinist order them but I will probably end up paying a little markup. Everyone is entitled to make money I suppose. Things are moving along for sure though and there is plenty of money moving out of my wallet.
The Kevko oil pan and pickup I ordered two weeks ago showed up yesterday as well. I had read a few things about watching for welding slag left over from manufacturing in their parts. So I took the pickup out of the wrapping and casually looked it over. Sure enough, I noticed a piece of welding wire still lightly stuck to the edge of the pickup screen. Guarantee that would have ended up badly. Glad I happened to notice it but I will be going over that stuff with a high-powered microscope before I cinch it down. Nice parts otherwise. The baffles, swinging door and built-in crank scraper in the pan are great. There is also a sight plug to establish correct fill level. Good stuff.
So depending on when the rest of the parts arrive, the block work should be completed within the next two weeks. Brian said the heads were delayed at the CNC shop. He expected to have them back late next week for final assembly. I hope to have all the components done and back in my possession by the end of February.
Sorry for the text-heavy updates gang, not much to document with imagery at the moment. It's all planning/parts ordering right now. Too cold to be out in an un-heated garage anyway.
More to come.
You go with diamond 51413 pistons?
Nice looking machine work...
