805moparkid
Slant and AFX Guy
well this went down hill quick... and he says its like the biggest carb... hmm... probably because its starting to get enough fuel!
boost modded carb? im sure not
pressure increase as boost increases? im sure not
correct piston to cylinder wall clearance? im sure not
correct ring end gap for boost? im sure not
threw new bearing in it? were they gauged? im sure not
that slant even now will be stronger than anything you can replace it will...
:wack:
when you put the small block chevy in i'll make you pop that motor trying to keep up with the slant!
:wack:
