1967formulaS
Hey guys, what size are the nuts that connect the master cylinder to the firewall? Tried all the ones I have laying around and none fit.
3/8 x 16Hey guys, what size are the nuts that connect the master cylinder to the firewall? Tried all the ones I have laying around and none fit.
What other donor cars can I get parts off? There aren't many 1968 Barracudas around.
What size is the ball-joint socket for the swap? I see a bunch online, don't wanna fudge it.
"This Kelsey Hayes disk brake swap should work for any A-body with the 5x4 small bolt pattern wheel, EXCEPT those with 13 wheels". Why does this swap not work for cars with 13" rims? Are they built differently?
is their way to swap drum to disc 69 dart rear
Is there any way to do same on rear of my 69 dart
You did a great job of documenting your disc conversion, thanks. Pictures made it helpful too.
