Dartsun
Mopar Dude
I'd try Mancini racing or eBay. Dustinanyone know where to buy the upper ball joint socket reasonably?
ah, forgot about ebay.. what size is it so i know what im looking for..?I'd try Mancini racing or eBay. Dustin
Insure you buy the correct ball joint socket. There is an early size (thru 1972) and a larger later size (1973+). I'd go dig for my early socket in the garage, but am sure you can quickly find it in a search now that you know. You can get it out w/ a large pipe wrench, but will scratch the paint, which is why I bought the socket for re-installation on my purtied-up UCA's.
Correct. Disk hubs are totally different than drum. The rotor bolts to the backside of the hub. The lower ball joints are also different (larger bolt holes).
I got the Front Disk Brake conversion..... So here is the deal if you are using stock 14" steel wheels that are 5.5" wide rim, I also kept the 5x4 bolt pattern which I had to have the RAM MAN make me a custom rotor. Also on the 64 it has the small upper control arms, so either you have to put the 10inch control arms in or, go to Dr. Diff or Ram Man and get hardened spacers for the upper A-arms to go into the knuckle.Anybody use a 4 wheel power disc brake conversion kit from THE RAM MAN on a 1964 barracuda? Any info would be great.
Thanks
This WILL NOT BOLT RIGHT ON!!!!! He sold me the 71-76 Dodge Dart Single piston. Told me it would work, does not work you need to shave off quite a bit of caliper and use spacers, now I forgot how wide the spacers are but they are the thinest ones out there. The car does stop great!!! I did also not use the rear brake residual pressure valve.
And I should have put disk brakes on a long time ago, BUT..... I SHOULD HAVE USED THE 65 KELSEY-HAYES SET UP!
I did not do enough homework and I hope this helps you. I am still some what happy with what I got, and I think a set of slotted Mags that are 7" wide should work fine, I have not tried yet. I will take this set up off my car in the winter and put on the K-H set up.
I have now amassed a lot of brake parts. the K-H Rotors are still available new. I have a complete brake set along with a spare brake booster if I never need it.
Please ask lots of questions. Bottom line if your using 14" rims you need to know the limitations.
So I hope it fits. The smaller ball joint is a hardened nickel sleeve so you can put the bigger steering knuckle on. His "salesman"? I thought he was a one man show.
If he is sending the big calipers I dunno. Me personally I would go with a Kelsey-Hayes since your staying with the small bolt pattern. Besides the extra $225 for custom drilled rotors its a lot of money.
After reading some of this I am glad that my car got original KH parts on it.... Only an obstacle or 2 but noting a little bit of hardware wouldn't fix.
I ended up getting calipers from hemi71X and could not have been happier. He obviously knows these parts very well....
JW
So I am concerned then on the rotors. They didn't make SBP rotors in those years they were all 5.5 by 71 for that caliper. Or so I thought. KH the way to go.The guys name is skip I believe and he told me the kit would fit no problems. I bought a kit from RIGHT STUFF and my rims wouldn't fit over the hub on the front rotors so I'm still concerned that his kit will not fit. I don't want to have to have the rotors machined to fit. So a little more homework and I thought this would be easy. Haha
Got mine from hemi71x as well. Even got the left hand threads. Wish I would have done this first. Do you have any pictures of the install?After reading some of this I am glad that my car got original KH parts on it.... Only an obstacle or 2 but noting a little bit of hardware wouldn't fix.
JW
I am going to start a thread in a week or 2 in regards to the brakes and will show the pictures. I went with Hydroboost and a few members are asking for details....
JW
Yep I did one. So here is my story.......Has any one used the rammam inc disc brake kit? All mopar factory kits look pretty nice
