I believe their from the company TTI bought out. CPPA I think. Their 20 years s and still like new. They fit awesome with my B engine. Don’t think they will fit with a RB though. KimOldkimmer, what headers are you running on the Duster? TTI?
That's bad *** right there! He should be talking with you!cal tracs, splits, ranchos, 275dr, SB 560ish hp, 3300#, 1.41-1.43 60's 10.60, 124
Just one car that proves otherwise. With Afco rear shocks it's gone 1.37's 60's and 10.53 - 125+.
I would stop talking to guys that don't and can't make them work and find guys that can and do make them work on A body mopars.
Im assuming assassin bars are in the same conversation as caltracs ? Same principal
Cool, thanks for the info RB, happy new year !Nope. You can adjust the Assassin bars. The Caltrac’s have almost no adjustment. The more power you make the more you have to crutch the Caltrac bar. You have to get more shock, change launch rpm and anything else you can do to not kill the tire at the hit. With the Asssassin bars, you can adjust some of that out. You can never get the instant center out far enough but you can get it much lower. It’s the same issues a ladder bar has. The IC is wherever that front bolt is. That’s usually too high and too far back for anything making over 400 hp. Guys just crutch it along, rather than go to a 4 link and tune it.
400 horse with ladder bars?
You drunk?
Guys going mid 4’s on ladder bars in the 1/8, lots of guys in the 4’s. 6’s and 7’s in the 1/4
Go snoop around on the bullet
Sheeeeeeeet, some guys do quite well on SS spring of all things.
Ladder bars definitely don’t work, neither do caltracs…
Other than a finer adjustment on how much leverage the bar has, what adjustments do assassin bars have that cal tracs don't?
Pay attention. I said ladder bars are limited in IC. That is just a fact. Just like a caltrac or the Assassin bar. Tell me, since you want to claim to be a chassis tuner how many cars out there want an IC 32 inches out? I say not many but with a ladder bar that all you get. Period. And the height is limited too. Just because you think guys going 4’s is impressive I say they may be several tenths quicker (maybe more) if they had a 4 link and learned how to tune it. Most guys refuse to learn, so the ladder bar is easy. Just weld them in and learn to live with it. So what I posted was exactly correct.
I don’t drink.
Many people doing something doesn’t make it the best or right way to do it.
Piss on the bullet. It’s a cess pool.
Only certain areas
Nope just whatever you bounced the *** of the car off the ground making sparks might be junk, lol.Caltracks and radials are junk. LolView attachment 1715848311View attachment 1715848312
So for a perfect ladder bar set up on a body would the front connection need to be up in where the rear passenger floorboards are ?
Do sliders help slow the tire hit ?It depends on power, wheel base, CG. I’ve seen some chassis that wanted the IC out past the bumper and at ground level. I’ve never seen a chassis that wanted the IC at half the wheel base and cam high, which is where most everyone ever said was the correct starting point.
